Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
Intel DX79SI Post Error 4F
CH3
Hi!
I was hoping someone could help me. I am running:
DX79SI (latest BIOS, Board revision 602)
Xeon E5-1620
16GB 1600MHz Kingston HyperX RAM
700W Enermax PSU
When I turn the Board on, the post starts but once it has reached 4f, it just reboots. The CPU is installed correctly and the contacts are looking good to me. What could the Problem be?
Thanks, Chris
Edit: After some checking i am now able to get a 36 error with the Bios Jumper removed. I guess (only guess) that the Problem is Memory related. I will check with different RAM tomorrow.
RRamo7
New Contributor III
Hello Chris,
We would like to recommend to you the following troubleshooting steps:
Check if you have already tested the items below (click the blue links to access the information):
  1. Most http://www.intel.com/support/motherboards/desktop/sb/CS-030386.htm?wapkw=desktop+motherboard+no+boot... a recent change to the computer
  2. Inspect for http://www.intel.com/support/motherboards/desktop/sb/CS-030386.htm?wapkw=desktop+motherboard+no+boot... b physical damage
  3. Inspect the motherboard http://www.intel.com/support/motherboards/desktop/sb/CS-030386.htm?wapkw=desktop+motherboard+no+boot... c LED light
  4. Inspect the http://www.intel.com/support/motherboards/desktop/sb/CS-030386.htm?wapkw=desktop+motherboard+no+boot... d CPU fan
  5. Check for http://www.intel.com/support/motherboards/desktop/sb/CS-030386.htm?wapkw=desktop+motherboard+no+boot... e Processor issues
  6. Check for http://www.intel.com/support/motherboards/desktop/sb/CS-030386.htm?wapkw=desktop+motherboard+no+boot... f Motherboard issues
  7. Check for http://www.intel.com/support/motherboards/desktop/sb/CS-030386.htm?wapkw=desktop+motherboard+no+boot... g Power supply issues
  8. Check the http://www.intel.com/support/motherboards/desktop/sb/CS-030386.htm?wapkw=desktop+motherboard+no+boot... h Display card / on-board display device
  9. Check the http://www.intel.com/support/motherboards/desktop/sb/CS-030386.htm?wapkw=desktop+motherboard+no+boot... i display monitor
  10. Check the http://www.intel.com/support/motherboards/desktop/sb/CS-030386.htm?wapkw=desktop+motherboard+no+boot... j memory / RAM
  11. Perform http://www.intel.com/support/motherboards/desktop/sb/CS-030386.htm?wapkw=desktop+motherboard+no+boot... k BIOS Recovery
  12. Perform CMOS Battery procedure
If everything looks like is in perfect condition but still doesn't work, please feel free to contact our support center at 916 377 7000 in order to claim your warranty on this product.
CH3
Hi!
Thanks for the answer. I decided to take out the CPU once again and do some visual inspection.
What I was noticing has been that one pin on the upper left side of the socket is slightly bent.
Also, if i take a look at the CPU under (very) bright light, some pins on the side of the bent pin are darker than the other ones.
The funny thing is that i did not notice any of this before, though I did inspect it as precise before.
I did also switch memory, so this can not be the Problem.
How shall I proceed?
Thanks, Chris
Side Note: Please answer me as soon as possible, the Client who ordered this pc is getting really angry. Both the Board and the Processor cost around 600€ altogether, and he doesn't understand why such expensice Components dont work together from scrarch.
RRamo7
New Contributor III
Hi Chris,
If there is a bent pin on the processor's socket in the motherboard, the only way you can go trough is getting in contact with our support center at 916 377 7000 in order to claim your warranty on this product.
CH3
Okay, thank you for the answer. I am now heading to my reseller (since I am in Austria) and going to claim the warranty.
Big thanks!
