Intel® Desktop Boards
Peer-to-peer support only
11432 Discussions
Intel DX79SI Shut Down and Reboot Issue
Community Manager
Hi There,
First off. My System Config:
CPU: i7 3930K
Motherboard: DX79SI, Bios Version: 0553
Memory: GSkill, RipjawsZ F3-12800CL9Q-16GBZL (4GBx4)
Graphic Card: Gigabyte GTX670, nVidia Driver Version: 306.97(WHQL)
Storage: Intel 520 Series 180GB
PSU: Seasonic 860watt Platinum
OS: Win7 Pro 64-bit, Service pack 1
ISSUE:
I use this system just for gaming only. I play Diablo 3 and Battlefield 3. During gaming the system will just shut down and restart by itself. Also one of the LAN ports does not seem to connect when it goes into desktop. I need to restart the system and then only it will connect. I have uninstall and install back the latest LAN driver but still the same.
I would really appreciate someone could help me out here. I just want a steady, stable system to play games if that's not too much to ask.
H
Community Manager
If your system is actually shutting down Windows vs. a sudden reboot with no shutodwn, I suspect the processor is overheating. Try installing the Intel Desktop Utilities and monitor the processor temperature. Perhaps the heatsink isn't fully contacting the CPU? OTOH, if your system is all of a sudden rebooting with no shutdown, suspect a memory problem.
As for the LAN problem, try replacing the ethernet cable. Sometimes you just get a bad or marginal cable that sometimes works sometimes doesn't.
Community Manager
Hi Brad,
The shut down goes like this. Screens goes blank, system fans stop (I'm guessing system has no power) and comes back on. Next Windows comes out with warning that it did not shut down properly and pops selection screen safe mode, normal windows, etc. Funny thing is the keyboard and mouse are dead at that point. So I have to wait for the count down of windows. Once it's in the windows log in screen, the keyboard and mouse are working again.
As for the CPU cooling, I'm using a Corsair H100 watercooling kit. Temps are 39C idle and 50C Load. Load meaning test running Intel Burn-in. For the LAN cable, I tried switching to a new ones, problem still the same. Used the current ones on an another system works fine.
ZAgha
New Contributor II
First lets take the power issue. Are you sure that you are supplying your PC with a clean surge protected power. Is it well grounded?
If you have a GOOD UPS try powering the PC from it.
Our systems are very much alike & I used to have the same problem until I solved it with a well grounded solution & a good UPS with surge protection.
Also make sure that the socket that is powering your PC doesn't have anything connected that drains power. Such as heater, hair dryer, etc...
PS I think the reason that you are unable to use your keyboard\mouse during boot is you have fast boot on which "in your case" disables the USB ports until windows load.
