Intel® Desktop Boards
Peer-to-peer support only
Intel DZ68BC
DJoy
Hello All,
I recently got a new (in box) Intel DZ68BC motherboard, I moved all my pieces over from an older Intel motherboard (as I wanted the extra PCIe slot) and now I cannot get my system to POST at all. When I put power onto the machine and attempt to power it up, I get the 3-BEEP then pause issue, which seems (from the manual) to mean that my Memory is failing? So, I attempted to replace it with working memory (I took it out of the system I'm working on now) and it's still giving me the same error.
Any suggestions of something I can attempt to fix before I have to put my old MB back into my system just so I can get it to work?
David
DJoy
Hello sir,
I'm not sure where you're getting this information, I was going from the Product Guide on the Intel website.
http://www.intel.com/support/motherboards/desktop/dz68bc/sb/CS-032686.htm Intel® Desktop Board DZ68BC — Product Guide
According to page 15:
Unbuffered, non-registered single- or double-sided DIMMs with a voltage rating of 1.65 V or less
Am I mistaken in this?
In response to your previous message, I will check the the BIOS model when I get home, if I can find it written on the board, as I do do not even get far enough in the boot process.
As well, yes I have tried using just one stick (All four sticks, attempted in each slot)
Thank you,
David
Jose_H_Intel1
Memory clock speed and voltage (1.5v) are ok. Try removing the CMOS battery and power for 20 minutes.
You may update the BIOS if you have a different working RAM.
Otherwise, ask the memory manufacturer about the density of the memory sticks; they need to match the requirements of the board in the link above.
