Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11361 Discussions
Intel DZ77RE-75K Wont shutdown
DOliv16
Hi my intel dz77re-75k motherboard wont power down completely when i click shutdown. I tried Windows 7 64bit, windows 8 64bit. It was shutting down but all of a sudden it stopped. I downloaded the latest intel bios for the board but not even that helped. Please assist me. All the ports of the board are working 100%. The pc works great but wont shut down.
Silvia_L_Intel1
Hello DucanDZ77RE-75K, thanks for joining the Intel Community.
These are some troubleshooting steps you can follow for this kind of behavior:
  • Test the system using minimum configuration out of the chassis (motherboard, processor, and power supply) No memory. Since there is no memory on it, the system should give 3 beeps.
If you have access to another system, please check the following link
http://www.intel.com/support/motherboards/desktop/sb/CS-029511.htm http://www.intel.com/support/motherboards/desktop/sb/CS-029511.htm
http://www.intel.com/support/motherboards/desktop/sb/cs-010254.htm http://www.intel.com/support/motherboards/desktop/sb/cs-010254.htm
DOliv16
Thanks Silvia. I will do that today. I installed the bios 066. The system was running 039 first. Which bios version do you recommend for this board that is actually stable?
DOliv16
Hi Silvia
I done what you said. I downgraded the bios to 057. I noticed that 057 is a bit more stable than 066 but im still struggling to shut the computer down. I am running a Corsair cx600 PSU. Im out of ideas and patients.
Silvia_L_Intel1
Have you tested the system out of the chassis?
If you are using a network card, could you please remove it and try to shut down the computer without it?
If you want to replace the motherboard , you can get in touch with our Warranty team if they are still under warranty, but if the problem is being caused by another device, the issue will continue.http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport or submit a web ticket at the following URL
https://servicerequestmgmt.intel.com/webticketui/emailpage.aspx?lang=en-us https://servicerequestmgmt.intel.com/webticketui/emailpage.aspx?lang=en-us
DOliv16
Hi Silvia.
I tested it out of the case as well and still the same thing. I do not want a other motherboard. I just want to know why when i shutdown the computer the computer goes into s5 state? isn't there a configuration that can be set.
Silvia_L_Intel1
Duncan, would you attach a picture of the "power tab" from the BIOS of your board, please?
DOliv16
Hi sorry for the late reply. I hope you can make out the image.
Hans_B_Intel
Hello, DuncanDZ77RE-75k,
Please explain exaclty what is the issue that you have encountered. You were reporting that your system won't shut down, do you mean shut down from within windows? Or a cold shutdown? Please clarify exacly what happens when you shutdown from within windows.
Answering your question: why when I shutdown the computer the computer goes into s5 state?
Shutdown from within the operating system would put the system in the S5 state/system shutdown; you can check the following link for more information regarding the S5 state.
https://msdn.microsoft.com/en-us/library/windows/hardware/ff564572%28v=vs.85%29.aspx https://msdn.microsoft.com/en-us/library/windows/hardware/ff564572%28v=vs.85%29.aspx
