Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
Intel® Desktop Board D2500HN
VValK
Pri zagruzke BIOS MB proizvodit dva korotkikh bip, pauza i snova dva korotkikh bip. Klaviatura ne initsializiruyetsya.
BIOS vosstanovleniye s flesh nakopitelya proiskhodit normal'no.
Sbros BIOS metodom izvlecheniya batareyki proboval.
Pamyat' ustanavlival druguyu - bez rezul'tata.
Na otsutstviye pamyati reagiruyet pravil'nymi bipami.
Vse lishniye ustroystva/kabelya otklyucheny.
Blok pitaniya menyalsya na zavedomo ispravnyy - bez rezul'tata.
Chto to yeshche mozhno sdelat' dlya ozhivleniya?
Spasibo.
When loading the BIOS MB produces two short beeps, a pause and then two short beep. The keyboard is not initialized.
BIOS recovery from a flash drive takes place normally.
Resetting the BIOS by extracting the battery tried it.
Memory installed another - with no result.
In the absence of memory reacts regular beeps.
All the extra device / cable disconnected.
The power supply is changed to a known-good - with no result.
What else can be done to revive?
Thank you.
Community Manager
Hi Kirval,
2 Beeps in a loop mean no graphics card detected. The graphics come embedded on your Atom processor. You already tried the BIOS recovery and tested with memories of DDR3 800/1066MHz 1.5V. It seems the graphics are faulty.
It is possible to test your motherboard using an external graphics card, it is necessary to use a card with the standard PCIe 1.0 plus it requires a riser card. You can get more details on page 45.
https://downloadmirror.intel.com/20717/eng/D2500HN_TechProdSpec05.pdf https://downloadmirror.intel.com/20717/eng/D2500HN_TechProdSpec05.pdf
Intel provides with 3 years of warranty on motherboards and processors since the date of purchase. If it is still under warranty contact our support team and request a replacement. Use the link below:
http://www.intel.com/content/www/us/en/support/contact-support.html http://www.intel.com/content/www/us/en/support/contact-support.html
Mike C
VValK
Spasibo.
Po vashemu sovetu pomestil v PCI graficheskuyu kartu.
ASUS 3DP-V264GT/PRO
Klaviatura teper' proinitsializirovalas'.
Na monitore pustoy ekran
Na vstroyennoy tozhe pustoy ekran.
Bipy ne izmenilis'.
Thank you.
On your advice I put in a PCI graphics card.
ASUS 3DP-V264GT/PRO
The keyboard is now initialized.
On the monitor, a blank screen
At the same built-in blank screen.
Beeps are not changed.
Community Manager
Hi Kirval,
Thank you for your update. Did you test your system using the external graphics card and 1 memory stick? If yes; I believe your motherboard got damaged. Intel provides with 3 years of warranty since the date of purchase.
Mike C
n_scott_pearson
Super User Retired Employee
You might also want to try testing with different memory. A bad DIMM can result in the board being unable to initialize graphics...
Hope this helps,
VValK
Memory tested twice.
Once on the other board, the second time a known-good.
I expect the reader POST codes.
He put the final diagnosis.
Thank you.
