Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Intel Desktop Board D975XBX2KR \ NO POST
neo01
Hello
I have the Intel Desktop Board D975XBX2KR and I am in no post situation.
I already tried to reseated the memory sticks \ reseated the graphic card \
no visible damaged to the board components or capacitors \ PSU is working 100%
tried to reset the bios \ I wonder what can cause this problem, I also notice that when no memory ram is installed there is no beep code (I test the speaker and he is working).
when I tried to force the bios by removing the pin head to configure mode there is a continually beep like its stuck and still no post.
appreciate your help.
Thank you
AlHill
Try a DIFFERENT power supply.
neo01
Hi
already tried that, no change.
try clearing CMOS, no change.
what is weird to me is when there is no ram connected at all there is no beep sound.
Thank you
