Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
Intel® Desktop Board DH55HC
BBaig
I have desktop PC with Intel® Desktop Board DH55HC, installed memory 2GB DDR. Can I upgrade my system memory by adding another 4GB DDR to 6GB?
Babar
Community Manager
Hello, BabarBaig:
Yes, your motherboard should be able to support 6 GB of RAM as long as you have DDR3 1066/1333. Here you can get more information about http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005876.html System Memory for the Intel® Desktop Board DH55HC.
Amy.
n_scott_pearson
Super User Retired Employee
Your board has four sockets for installing memory DIMMs. Two of these sockets are for DIMMs that will be connected to the chipset's first memory channel. The other two are for the chipset's second memory channel. At present, I will presume that you have two 1GB DIMMs in the first and third sockets (or the second and fourth; namely to have one connected to each memory channel [Aside: so that interleaved accesses can occur]). You need to move one of these DIMMs to a different socket so that the two DIMMs are connected to the same memory channel. Then, you can install the new DIMMs in the sockets for the other memory channel.
Overall, the point I am trying to make is that the DIMMs connected to a memory channel need to closely match (i.e. be the same size and same speed)...
Hope this helps,
...Scott
BBaig
Hi
I have a single 2 GB DIMM now want to install another 4GB module. Will this configuration work?
Babar
n_scott_pearson
Yes, provided you have them in different channels.
Community Manager
/thread/101330 BabarBaig, let us know if you are able to add the RAM.
Amy.
Community Manager
Hello, BabarBaig:
Were you able to add the RAM?
Let me know your findings.
Amy.
