Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Intel Desktop Board DP35DP fails to post correctly after bios update
RMarx
Have an Intel Desktop Board DP35DP it was working etc did an upgrade of the bios for the new cpu i installed and after the upgrade it rebooted but hangs with a non flashing white dash on the top left corner of the screen.
have tried a bios recovery and that does the same
AlHill
Have you tried going back to the old cpu? What is the model number of the new cpu?
Doc
RMarx
have not changed the cpu out made the bios update with the same cpu , only thing is it did not know what cpu it is
its Q9505
have tried a throng of other cpus as well all does the same
was looking for a previous version of the bios but could not find out to see if it wil actually downgrade to that
swopped out memory and gpus to see if perhaps if that is the problem
AlHill
Your post makes no sense.
You can find all of the bios updates here:
https://ark.intel.com/content/www/us/en/ark/products/50380/intel-desktop-board-dp35dp.html
Personally, with a board this old, and the problems you are having, I would take the board to a recycle bin.
Doc
AlHill
Here is a list of supported processors for your board:
https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/desktop-boards/DP35DP.pdf
If your new processor is not on this list, there is your problem.
If your new processor is on this list, the processor may be defective, especially considering its age.
If your old processor still works, the bios update is good.
If your old processor no longer works, then the bios update is bad, or the board suffered damage in the processor upgrade process.
Doc
