Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
Intel® Desktop Board DX48BT2 No POST
Community Manager
Bought the board several years ago finally got around to building it. Board will not post (no video). Have breadboard down to compatible cpu (q9650) and one ddr3 4GB dimm 1333 in correct channel, gpu and monitor. (3 beeps with no memory and no beeps with memory). Board goes into reset cycle and will not post (jumper 1-2) The manual says up to 8 GB supported 2 GB dimms. Is the problem caused by the larger memory stick? Tried normal troubleshooting and nothing works. Welcome any help please? Thanks!
Community Manager
OK was memory error caused by unsupported DIMM configuration 2x4GB. The older board only supports 4x2GB so close this and thanks.
Community Manager
That is a 2008 model. Battery life is about 5 years.
http://www.batterybob.com/category.asp?cat=9024 CR2032 Battery Group (Page # 1)
Community Manager
I appreciate the suggestion. No already checked the battery 3v tested all psu cables volts amps etc. so not the cause. Hope somebody else can please help with this.
Community Manager
