Community
cancel
Showing results for
Search instead for
Did you mean:
SVanc2
Intel Desktop Board DZ77GA-70K & Windows 8 PRO 64bit problems...
Hi folks,
Yesterday i have built my new computer.
Specs are : intel dz77ga-70k, core i7 3770, 16gb ram, ssd corsair, ...
I have a problem with windows 8.
It already started when installing windows 8, the computer said : windows will restart in 10 seconds,
after this the computer hanged and did not reboot, i had to reboot myself.
After i had finish the installation i install the latest bios for the board, its number 60. ( it was 21 before )
With the new bios I still have problems with rebooting or shutting down windows 8.
Sometimes it hangs, sometimes not.
Can someone help me please...
Bios is set to default and the only thing i have changed is the xmp-1600 profile for my memory, that works !
UEFI boot is enabled and legacy boot is enabled too ( both were standard enabled )
And sorry for my bad english, i'm from belgium
I think this will be fixed in a new bios version soon, the compatibility with windows 8 isn't that great for the moment.
Community Manager
It is a problem with the BIOS, wait for Intel to solve the issues. It only happens in UEFI mode, if you turn off UEFI and install in Legacy mode then it will not freeze.
SVanc2
Okay, thanks for the information.
I will keep on working this way and I hope that intel will fix this problem soon.
Community Manager
I purchased a new video card, EVGA GTX 660ti and updated it with UEFI firmware. I installed Windows 8 using Secure Boot (Legacy Boot off), at the end of installer it rebooted fine. I restarted 5-6 times in Windows and it did not hang, 2 times it did reboot slowly, took about 5 seconds.
Now i also did this: http://www.askvg.com/fix-windows-8-restart-and-shutdown-problems-by-disabling-hybrid-shutdown-featur... Fix Windows 8 Restart and Shutdown Problems by Disabling &# 8220;Hybrid Shutdown&# 8221; Feature - Tweaking with Vishal
Will do some more testing to verify that it does not hang.
SVanc2
@dislikeyou :
I have tried the fix in windows 8 and now it works perfectly !!!!
The computer shuts down perfectly and it reboots perfectly ! I have tried like 10 times and no problems occured.
Thank u very much for this great fix
But intel still needs to fix the bios because when we install windows 8 in uefi we can have the 'hang problem' when the installer says to reboot the computer...
SVanc2
Damn...
When i have tried to shutdown the computer for the 11th time it hanged
But it occurs not that often anymore ...
SVanc2
Hmmm but with the second fix ( the one with disabledynamictick ) is everything ok for the moment...
There is a serious problem with windows 8...
I let u know if its fixen now...
Community Manager
Good if it works. I have not used the disabledynamictick fix yet but for me it did not hang so far, sometimes it takes 1-3 seconds to restart/shut down, but some other times it takes 30 seconds or more, i did not have to use the Power button shut down, which is good.
SVanc2
The second fix still works for me man
The computer shuts down correctly.
I hope in the next bios update we see in the release notes : full win8 support
Community Manager
I still have the problem
Any sugestions, please?
Community Manager
For me it works except that it sometime takes 20-30 seconds to restart/shutdown.
I have not disabled fast startup and i have not used the dynamictic trick.
Why it still hangs for you, i don't know. Are you booting in UEFI mode?
Community Manager
When i restart or shut down i get this error DPC_WATCHDOG_VIOLATION.
Community Manager
No, I don't boot in UEFI mode.
Community Manager
I've searched for this error, and I found, on Microsoft website, that is caused by a driver. I have updated all drivers from Intel website, but the error persists.
I've used Windows 8 32bit for one week and i had no problems. After I've installed Windows 8 64bit I've started to encounter this error, even when I installed the OS, at the fierst restart my computer freezed.
SVanc2
So my windows 8 worked for me perfectly after i dit the 2nd fix (disable dynamictick).
Yesterday there were 2 updates of windows 8 after i activated the windows...
I installed the updates and after those 2 updates i'm having the same problems as before ...
I re-entered the dynamictick thing but the problems weren't away
I re-installed windows 8 in legacy boot (disabled uefi) and the problems weren't gone, it hangs when i choose to
restart or to shut down the computer.
So i installed Windows 7 and this works perfectly !!!!
I don't understand it anymore, i think we all have to wait for a bios update that works perfectly with win8.
I will use win7 now and when all the problems are gone i will re-install win8
SVanc2
@dislikyou :
When i installed this morning win8 : legacy boot was enabled and uefi boot was disabled...
Do i have to disable the legacy boot too for having no problems with shutting down win8???
Anyway i will keep on using win7 for a while now....
Community Manager
I have only UEFI boot turned ON, Legacy Boot is OFF. But i have a UEFI graphics card.
Maybe that is why it does not hang for me, because i have Legacy Boot turned off.
If you want to try, you can enable IGP, enable UEFI boot and turn off Legacy Boot, install Windows 8 and see if the problem still exist. Connect the monitor to IGP.
SVanc2
I will now continue working with win7 for a while, i will wait for a new bios update and then install win8 again.
@dislikeyou : Normally win8 must work with uefi boot & legacy boot both enabled ??
Can u explain to me what the difference is between both?
I don't quite understand...
I now one think it doesn't work right now
Community Manager
Yes, normally it should work with both enabled.
When you turn off Legacy Mode, then it runs with only UEFI firmware, there is no BIOS emulation.
I'm not sure when Intel will fix it, maybe it will take several months :/
Community Manager
I upgraded to bios 0061 and it seems to reboot normal. I only tried to reboot 3 times so i am not sure yet but i will test more tomorrow.
SVanc2
I will keep on working with bios 60 and win7 for another 2weeks and then i will :
upgrade to bios 61, set everything to default ( uefi enabled, legacy enabled ), the only thing i will change is
my memory to the xmp-1600 profile...
then i will install win 8 pro again and i hope EVERYTHING is fixen !!!
normally it must be fixen when i u read the release notes... there are many reboot/shutdown hang problems fixen.
can u let us know dislikeyou if everything works fine with win8 ( uefi & legacy enabled )
thanks
