Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
11381 Discussions
Intel® Desktop Board DZ77SL-50K PCI & PCI E Use Same IRQ
SIT4
I have purchased "Intel® Desktop Board DZ77SL-50K" on which i have connected One PCI Openvox 8 Port Analog Card and one PCI-E Openvox 8 Port Analog Card on my Asterisk Elastix Version # 1.8 Lunix Server. For some reason when make & receive calls, i get lots of noise disturbance. When I check Cat / proc / interrupts from root. I found
CPU0 CPU1 CPU2 CPU3
90 : 46010866 10326340 0 0 IO-APIC-LEVEL OPVXA1200, OPVXA24xx
I upgraded Dahdi drivers & card Drivers. To resolve temporary, I have to connect extra available Openvox 8 Port Card on another PCI Card, now it shows different IRQ
CPU0 CPU1 CPU2 CPU3
90 : 46010866 10326340 0 0 IO-APIC-LEVEL OPVXA1200 (PCI), OPVXA24xx (PCI-E)
169 : 66010866 45426340 0 0 IO-APIC-LEVEL OPVXA1200.(PCI)
Then I only use PCI-E from First 1 Line and PCI from Second to continue our system running, I spoked to many asterisk or linux experts, they said its problem with Motherboard issue. They will well support you.
Im looking for a solution configuration or setting either from Intel Motherboard Bios or OS Linux setting Configuration to have PCI or PCI-E Card own seperate IRQs for each card.
Please help me, Thanks in Advance
Sam
Salem_W_Intel1
As your inquiry pertains an Intel® desktop board, please, know I have rerouted this post to the corresponding support department.
Silvia_L_Intel1
Hello ITsupport5589,
It is important to tell you that Intel has not tested and validated Intel® boards on any Linux versions; we know that other customers have successfully installed it.
Regarding IRQs, there are some links that shows how to change IRQ manually on Windows 7 or 8.1
http://windows7themes.net/en-us/how-to-change-irq-in-windows-7/ http://windows7themes.net/en-us/how-to-change-irq-in-windows-7/
http://www.helpwithpcs.com/upgrading/change-irq-settings.htm http://www.helpwithpcs.com/upgrading/change-irq-settings.htm
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
