Hi. My configuration:
Intel DZ68DB Desktop Board
Windows 8 Pro x64
Latest Intel's drivers and software installed.
Intel Desktop Utilities IDU_3.2.4.055b shows nothing but blue loading circle. I have no problems with ICU on Windows 8 Release Preview.top
- Tags:
- Desktops
I am also having same problem. And tried changing compatability to Windows 7 but it didn't worked.
Board is DH67CL
OS: Windows 8 PRO x64
I think we should wait for new release of the software
You shouldn't be seeing any compatibility issues with Windows 8. Please tell us more about your hardware configuration. Are you, for example, utilizing RAID (and Intel Rapid Storage Technology)? Have you customized any BIOS parameters?
Hi Scott.
I have no RAID. My configuration:
Intel DZ68DB Desktop Board with latest (0043) BIOS
Intel Core i7-2600K CPU
Intel HD Graphics 3000
8 GB RAM
2 Seagate HDD
Sony Optiarc BD-5300S drive
1 additional (front panel) fan
Windows 8 Pro 64-bit
About BIOS settings. I changed 2 or 3 settings. Nothing special, but let me know if you need it, and I'll check and post it here.
I saw your messages in other topics. So, my FSCAppServ.log:
01/01/13 23:17:18 INFO Service Loading; Version = 1.1.2.28
01/01/13 23:17:20 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/01/13 23:52:46 INFO Service Loading; Version = 1.1.2.28
01/01/13 23:52:52 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/02/13 16:31:27 INFO Service Loading; Version = 1.1.2.28
01/02/13 16:31:32 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/02/13 21:37:34 INFO Service Loading; Version = 1.1.2.28
01/02/13 21:37:41 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/02/13 21:56:48 INFO Service Loading; Version = 1.1.2.28
01/02/13 21:56:57 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/04/13 15:07:38 INFO Service Loading; Version = 1.1.2.28
01/04/13 15:07:46 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/06/13 17:26:55 INFO Service Loading; Version = 1.1.2.28
01/06/13 17:26:58 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/06/13 17:27:53 INFO Service Loading; Version = 1.1.2.28
01/06/13 17:28:00 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/06/13 19:30:06 INFO Service Loading; Version = 1.1.2.28
01/06/13 19:30:12 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/06/13 20:16:32 INFO Service Loading; Version = 1.1.2.28
01/06/13 20:16:35 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/06/13 20:26:55 INFO Service Loading; Version = 1.1.2.28
01/06/13 20:27:04 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/10/13 08:42:04 INFO Service Loading; Version = 1.1.2.28
01/10/13 08:42:08 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/10/13 08:50:56 INFO Service Loading; Version = 1.1.2.28
01/10/13 08:51:04 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/11/13 23:27:43 INFO Service Loading; Version = 1.1.2.28
01/11/13 23:27:50 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/11/13 23:33:54 INFO Service Loading; Version = 1.1.2.28
01/11/13 23:34:00 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/11/13 23:37:58 INFO Service Loading; Version = 1.1.2.28
01/11/13 23:38:05 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/11/13 23:47:58 INFO Service Loading; Version = 1.1.2.28
01/11/13 23:48:06 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/11/13 23:51:00 INFO Service Loading; Version = 1.1.2.28
01/11/13 23:51:08 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/12/13 18:13:54 INFO Service Loading; Version = 1.1.2.28
01/12/13 18:14:02 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/15/13 14:35:39 INFO Service Loading; Version = 1.1.2.28
01/15/13 14:35:42 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/20/13 22:33:13 INFO Service Loading; Version = 1.1.2.28
01/20/13 22:33:21 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
01/20/13 22:35:10 INFO Service Loading; Version = 1.1.2.28
01/20/13 22:35:16 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
02/07/13 15:05:43 INFO Service Loading; Version = 1.1.2.28
02/07/13 15:05:46 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
02/07/13 15:18:41 INFO Service Loading; Version = 1.1.2.28
02/07/13 15:18:51 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
02/07/13 18:20:46 INFO Service Loading; Version = 1.1.2.28
02/07/13 18:20:49 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
02/07/13 22:48:17 INFO Service Loading; Version = 1.1.2.28
02/07/13 22:48:26 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
02/07/13 22:50:48 INFO Service Loading; Version = 1.1.2.28
02/07/13 22:50:56 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
02/13/13 21:01:06 INFO Service Loading; Version = 1.1.2.28
02/13/13 21:01:12 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
02/13/13 21:18:18 INFO Service Loading; Version = 1.1.2.28
02/13/13 21:18:35 ERROR EFIVarGetVariable() failed, ccode = 0x02 (EFI_DRIVER_NOT_INSTALLED)
After upgrading to Windows 8, Windows 8.1 or Windows 10, you have to manually uninstall and then reinstall Intel Desktop Utilities (IDU). Why? Microsoft, for some unknown reason, trashes some of the drivers that IDU requires during the upgrade process.
...Scott
P.S. For any 6 Series or later board, I recommend that you install IDU v3.2.8.089.
