Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
Intel ME 8 Management Engine
ln31
DZ77BH Motherboard
I see IME listed on my boards download page, is this something I absolutely need to install?
~Benefits ?
~Downsides ?
I've read up on it and I see the new MEI is different than what it used to be.
I noticed that Yellow Exclamation mark in Other Devices> PCI Simple Communications Controller.
Every thing works fine though so I may not even need it.
I don't want to install fancy interrogation stuff if I don't need it, but I don't want to limit my PC functionality.
What is the most experienced consensus on this.
AP16
Valued Contributor III
Management Engine is a MB part, which support corporate PC management infrastructure, like remote WakeUp or remote mass BIOS updating/CMOS settings propagation. In some notebooks this component also support user-level anti-theft lockdown protection, but for home desktop user this driver is just an exclamation mark remover (and a potential security hole, if someone took hands on this bunch of drivers and services with kernel-mode privileges)
ln31
Well thanks for the info JFFulcrum
I've read up on it quite a bit and can see as far as I can tell, it's really not needed for the home user, and may be more trouble than it's worth.
Perhaps to just get rid of the yellow exclamation mark, I've extracted the installer and have 'isolated' this one folder out of it:
.............\Drivers\MEI
..and in this folder are only 4 files which are:
heci.cat
HECI.inf
HECI.sys
HECIx64.sys
...and so if I point the DM drivers update to just this folder I have a good feeling it will remove the yellow ! ...but won't install the rest. I guess I can try it on a test bed setup to see what happens.
