INTEL DESKTOP BOARDS - DH61WW
Earlier I was using Windows XP
and few months back I encountered one problem
As and when I start my PC, my LAN does not work
SO I have to disable every time and then enable to make it work
I tried reinstalling and updating Ethernet driver also few times but none helped
Then I switched to Windows 7 and still facing the same problem
but now I have to Restart every time to make Ethernet Connection WORK
Please advice or provide a solution
Hello, YashJ:
Could you please let me know the BIOS version installed?
Amy.
What BIOS version? What processor? What memory? What things have you changed in BIOS Setup?
BIOS Version - BEH6110H.86A.0038.2012.0110.1653
Processor - Intel Core i3-2120 3.30 GHz
Memory - 4GB (1333MHz Speed)
No I have not changed any settings in BIOS
all set to DEFAULTS only
You are on BIOS 38 and the latest available is 120. That's a lot of BIOS releases and a lot of upgrades and bug fixes that you are missing. Here is a link to the page where you can download more-recent BIOS releases (and drivers): https://downloadcenter.intel.com/product/51856/Intel-Desktop-Board-DH61WW DH61WW Drivers & Software. As well, here is a link to the download page for the latest BIOS release: https://downloadcenter.intel.com/download/23393/BIOS-Update-BEH6110H-86A-?product=51856 Download BIOS Update [BEH6110H.86A]. I include this second link because it provides instructions regarding the order for installing BIOS updates (you cannot just install the latest BIOS (don't try; you would likely brick your board!); you must install a few releases along the way for it to work properly).
For more information, consult the following documents:
http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005547.html?wapkw=b... BIOS Update Instructions for Desktop Boards
http://www.intel.com/content/www/us/en/support/boards-and-kits/000005630.html?wapkw=bios+recovery Recovery BIOS Update Instructions for Intel Desktop Boards
http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005859.html Updating the BIOS to Support 3rd Generation Intel Core Processors
Hope this helps,
N.Scott.Pearson, thank you for your feedback.
YashJ, please try that suggestion and let us know if it helped.
Amy.
/thread/102270 YashJ, were you able to tack this down?
Amy.
right now I am out of town
as and when I reach back home
I'll give it a try and share the result
Hello I tried updating my bios from 0038
but my intel management engine firmware
IS SHOWING
0.0.0.0
Kindly help me out here
If your Management Engine (ME) firmware revision is displayed as 0.0.0.0, it means that the ME is not running - which usually means that the ME does not have valid firmware to run. When this is the case, the only thing that you can try is reinstalling the BIOS using the Recovery method. This method is documented here: http://www.intel.com/content/www/us/en/support/boards-and-kits/000005630.html?wapkw=bios+recovery Intel Desktop Boards Recovery BIOS Update Instructions. Reinstall BIOS 38 this way. If it succeeds, follow this process for upgrading the BIOS: http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005859.html Updating the BIOS to Support 3rd Generation Intel Core Processors.
Hope this helps,
Hello, YashJ:
I wanted to follow up your case.
Were you able to track this down? Did the previous post help you?
Amy.
yes upgrading BIOS solved my problem
and since then
there has been no issue and working fine
thanks
