I have a RAID 5 array with 3 drives. Recently one of the drives failed. No big deal I thought. I swapped the drive and rebooted. The bios asked me if I wanted to use the new drive, I said yes. It said it would rebuild in Windows. Makes sense. Go into Windows and the Storage Manager Console says the 2 drives are offline members. I can't figure out how to get them online. I reboot and the bios sees them as offline members as well although it clearly sees they are present. I think most of the data is backed up but it is about 7 years of home photos and videos. I'm afraid some of the videos may not have been picked up by Carbonite so I'd like to get the array rebuilt. Any clues on how to get it to see the two remaining drives as online so it can start a rebuild?
When the hard drives appear offline it means that the RAID could be corrupted but it does not mean that the hard drives are bad.
You can access the RAID BIOS in your motherboard and set only that hard drive to non RAID disk; that will delete the RAID structure from that hard drive, then in Windows from the Intel Matrix Storage Manager software you can rebuild the RAID 5 volume using that Hard Drive again.
I had one drive fail. I could hear it spinning down and attempting to spin up. I replaced it. When I rebooted, the BIOS prompted to add the new drive (or something like that). When I got into Windows the storage manager didn't load and I had errors so I rebooted. This time the BIOS showed the other two drives as offline members. I don't think I remove them. It seems like they have been erroneously marked as offline. I'm looking for some way to mark them as online again so that the storage manager software can re-build the array.
You might want to re-post this query in the Chipsets support forum. There are experts monitoring that forum that can better handle issues related to Intel RST.
...Scott
P.S. I would move it over for you if I could figure out how it is done...
