Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
Intel Matrix Storage Manager Raid 1 Hard Drive Replacement
JJ12
I am having a problem getting a replacement hard drive back into raid 1. My I&-920 Volume is missing a hard drive which I just replaced. There is no option to rebuild the volume or anything like that. Help please. Thanks.
Jose_H_Intel1
Hello usfjosh,
Just to make sure, right-click on the non-RAID hard drive in the device tree and select Rebuild to this Hard Drive, as per page 19 of the Intel® Matrix Storage Console user guide (assuming the replacement drive is same or higher capacity than the failed drive).
http://download.intel.com/support/chipsets/imsm/sb/imsm_reference1.pdf http://download.intel.com/support/chipsets/imsm/sb/imsm_reference1.pdf
You may also reset both drives to non-RAID, as you have a RAID 1 the data will remain on the original member drive. Then, recreate the RAID with Intel® Matrix Storage Console and choose the option to keep the data from the original member drive. Please note such option is not available from Ctrl+I.
In case further assistance is needed please copy/paste the system report generated from Intel® Matrix Storage Console's help menu.
