Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Intel MoBo: D845GERG2
I've got a Intel D845GERG2 MoBo with an Intel P4 2.80 GHZ (Socket 478 / Speed 533 MHZ) processor. The OS that's installed is MS Server 2000 (Domain Controller.....). (Serious home / small business setup). I've had this configuration for about 5+ years. (With no issues). I understand this MoBo is no longer supported. However, does anyone know if the MS Windows Server 2000 drivers (Intel web site for legacy MoBo's) will support MS Windows Server 2003 R2 Standard Edition? (Cash strapped. However, if need be I can upgrade.)
Highlighted
Honored Contributor I
1 View
Re: Intel MoBo: D845GERG2
You would be better off checking with Microsoft. They have where you can check hardware compatability.
