Community
cancel
Showing results for
Search instead for
Did you mean:
makoch
Intel (R) 7 series/C216 Chipset family usb enhanced host controller- 1E26
"In der Treiberinstallationsdatei für dieses Gerät fehlt ein erforderlicher Eintrag."
This effect is since the last win 10 Update. It makes my USB 2 ports out of work.
I checked all the supportpages and did not find a newer driver. The SSU.exe program didn't work as well. The "submit" link failed.
Is there any solution to this issue or do I have to wor without the USB ports?
Best regards
makoch
makoch
Her's the result from ssu.exe
Aubi
Ich habe das gleiche Problem. Wurde bereits eine Lösung gefunden?
Gruss Aubi
n_scott_pearson
Super User Retired Employee
The drivers for the USB controllers in 7 Series chipsets are all built into Windows 10. Intel does not provide any drivers separately. Are you sure you aren't having a problem with additional USB controllers on the motherboard? In this case, you should be approaching your motherboard manufacturer for the drivers for these controllers.
Aubi
Danke für Deine Nachricht. Nachdem ich die System-Komptabilität mit einem BIOS Update durchgeführt und alsdann den USB Host Controller mittels Update aufgefrischt habe funktionieren nun alle Komponenten wieder einwandfrei. Beste Grüsse Aubi
