Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
Intel(R) Management Engine Interface driver has failed to start
Community Manager
I am using intel mother board, details given below:
The issue that i am facing is Intel(R) Management Engine Interface is not getting started. I have downloaded and updated all the drivers and even i have updated the bios version as well but the issue still persists.
I have changed the Operating system as well, i have tried with windows 8 and windows 7 as well but the same issue persists on both OS.
Due to this everytime when i start the PC ethernet card is not detecting with the error "Unable to start the network adapter". So everytime i have to do uninstall the network card and do a scan for h/w changes which is really annoying!!
Please help on this matter.
Board details
Board Model :DH67BL
Board version : AAG10189-211
BIOS VERSION : BLH6710H.86A.0160.2012.1204.1156
os : MICROSOFT WINDOWS 7 ULTIMATE
Event logs
Log Name: System
Source: MEIx64
Date: 6/29/2013 11:33:23 AM
Event ID: 3
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: admin-PC
Description:
Intel(R) Management Engine Interface driver has failed to perform handshake with the Firmware.
Event Xml:
http://schemas.microsoft.com/win/2004/08/events/event">
3
2
0
0x80000000000000
5864
System
admin-PC
000000000100000000000000030007C0000000000000000000000000000000000000000000000000
Log Name: System
Source: e1cexpress
Date: 6/29/2013 11:33:39 AM
Event ID: 24
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: admin-PC
Description:
Intel(R) 82579V Gigabit Network Connection
PROBLEM: Unable to start the network adapter.
ACTION: Install the latest driver from "http://www.intel.com/support/go/network/adapter/home.htm http://www.intel.com/support/go/network/adapter/home.htm".
Event Xml:
24
2
0
0x80000000000000
5865
System
admin-PC
000004000200300000000000180004E0000000000000000000000000000000000000000000000000180004E0
Silvia_L_Intel1
Rijesh, please let me know if this error appears recently or after a BIOS updated.
If so, I would recommend you to roll back to the previous BIOS version and check if the behavior is the same. Instructions will be found here:
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS update
Please let me know.
Community Manager
Hi Sylvia,
This behavior was there even before the BIOS was upgraded.
Some of the threads in Intel forum suggested to update BIOS and drivers to the latest version, hence i have upgraded BIOS and all drivers to the latest available version.
Please help....
Silvia_L_Intel1
Rijesh, BIOS version 0160 and 0159 have the same Management Engine version.
Again, I would recommend you to roll back to BIOS version 0156 and then update the BIOS again.
If you continue having the same behavior, feel free to contact your local support group for assistance on replacing your motherboard: http://www.intel.com/p/en_US/support/contactsupport?group=processor http://www.intel.com/p/en_US/support/contactsupport?group=processor
