Intel® Desktop Boards
Peer-to-peer support only
11480 Discussions
Intel(R) Matrix Storage Manager
AAndr31
From time to time, Intel (R) Matrix Storage Manager Version: 8.9.0.1023 - https://downloadcenter.intel.com/download/17882/Intel-Matrix-Storage-Manager https://downloadcenter.intel.com/download/17882/Intel-Matrix-Storage-Manager, detaches one of the drives (RAID 1) - incomplete Volumin Raid. The disk is operational. Why? And then update the technology?
Andrew
n_scott_pearson
Super User Retired Employee
I have an Intel 7 Series board managing a 4-drive RAID5 array. It has been running for a couple of years now. I currently have RST version 12.8.0.1016 installed. I have never seen a detach issue occur...
EstebanA_C_Intel
Hello, eskadra1:
Thank you for contacting the Intel Communities.
Have you tested different SATA cables?
You could also back up all your data and then format the drive that your are having issues with and then re-build your RAID.
Please do backup all your data before doing this since we cannot assure it is going to recover properly, RAID is a very tricky configuration for that reason it would be better to have the information safe somewhere else.
Esteban C
AAndr31
Thank you Esteban and N. Scott Pearson for the answer.
There are two drives Segat. Intel (R) Matrix Storage Manager disables random drives. That's the problem. Once one drive and once the second drive :-)
Can you update the Intel (R) Matrix Storage Manager Version: 8.9.0.1023 for Intel® Rapid Storage Technology 14.8.0.1042 ??
Andrew
n_scott_pearson
EstebanA_C_Intel
Hello, eskadra1:
That is correct, I would like to know, what is the maker and model of your motherboard?
Esteban C
AAndr31
Data motherboard:
Asustek Computer INC.
Model: P7P55 LX
Procesor: Intel(R) Core(TM) i5 CPU 661@3.33GHz.
Bios: American Megatrends Inc. 1101.
RAID Intel(R) ICH8R/ICH9R/ICH10R/DO/PCH SATA RAID, number of ports: 6
Thank you
Andrew
EstebanA_C_Intel
Hello, eskadra1:
You should not have any issues while updating the Intel(R) Rapid Storage Technology driver in your system.
If you require any additional information or support, feel free to advise us.
Esteban C
AAndr31
Thank you very much. If problems are to write.
EstebanA_C_Intel
Hello, eskadra1:
No problem, we all the communities' user are here to assist each other for sure.
Esteban C
