Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel RS2BL040 Firmware
Hello!
We have Intel (R) RAID Controller RS2BL040 with INTEL S5520UR motherboard:
Adapter # 0
Versions
Product Name : Intel (R) RAID Controller RS2BL040
Serial No : SV11101129
FW Package Build: 12.12.0-0036
Mfg. Data
Mfg. Date : 03/05/11
Rework Date : 00/00/00
Revision No : 67B
Battery FRU : N/A
Image Versions in Flash:
FW Version : 2.120.13-1094
BIOS Version : 3.20.00_4.11.05.00_0x0418A000
Preboot CLI Version: 04.04-017:# %00008
WebBIOS Version : 6.0-32-e_27-Rel
NVDATA Version : 2.09.03-0010
Boot Block Version : 2.02.00.00-0000
BOOT Version : 01.250.04.219
Pending Images in Flash
None
I've updated firmware to 12.12.0-0111, after rebooting controller is beep every 1 second but controller was fully functional.
Result was the same with firmwares 12.13.0-0104 and 12.12.0-0048.
Then I've updated firmawre back to 12.12.0-0036 and the controller has stopped beeping.
Is there something wrong with firmware 12.12.0-0111 or our controller doesn't support this firmware?
Tags (2)
Community Manager
Hello Max,
I recommend you to post your inquires on the server communities forums as this forum is for desktop motherboards only and we will not support the Intel(R) controllers or server motherboards from here.
Regards.
PV
