I had to enabled EFI mode because windows server just wouldn't let me install on MBR. when I was originally testing the board I had the GPU installed and EFI off and GPU worked fine. I read somewhere that you have to disable secure boot but that option is literally nowhere to be found as this motherboard is pretty poorly equipped unfortunatly. after work I was going to disable IGP and see if maybe there was a conflic but at this point i'm just grasping at straws. any suggestions on what I can do or is it just a compatibility thing.
specs:
CPU: x3460
MOBO: S3420GP
GPU: Quadro M2000
Memory; Single ECC DIMM 4gb for testing will install more later
Thanks for any assistance you guys can offer!
