Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
Intel board DZ87KLT-75K, no sound =(
ZStul
Built my first pc and it was an experience! Everything went smoothly except for me having no sound / recording device work on my motherboard or front panel ports ( GREEN & PINK PORTS ) I have tried many different types of headphone none will give sound. I have tried everything i believe in audio manager and have the latest audio drivers from intel ( REALTEK hd ). I'm actual just using a USB ONLY headset/mic because its my only options. Any ideas?
Kevin_M_Intel
Hello Zach_S
I have been testing the same unit I have next to me and I was not able to replicate the problem.
I recommend you doing the following:
1- Check the Sound properties under Playback, make sure you have the correct device set as Default Device
  1. Make sure you have connected the speakers or headphones in the correct output.
I have done a clean installation of the operating system and installed all drivers and it is working fine for me.
