Intel says it DOES support VT-d, at
http://www.intel.com/support/motherboards/desktop/sb/CS-030922.htm http://www.intel.com/support/motherboards/desktop/sb/CS-030922.htm
(see last table on that page).
Intel says it DOESN'T support VT-d, at
http://ark.intel.com/compare/70898,70903,69045 http://ark.intel.com/compare/70898,70903,69045
Trying to build a configuration with totally non-kludged, orthodox, VT-d end-to-end support is hairy enough as it is, which is a major reason for leaning toward Intel boards in the first place.
How can a customer know, is the list on the CS-030922 page 100.0000 percent reliable and authoritative, or not?
Nusrat,
Thanks a lot for you comment. This has been already escalated in order to update the information in the web site.
Regards.
Sylvia, you say "to update the information in the web site."
But what does that *mean*?
It tells me that at least one web page will be corrected,
but it doesn't really answer the question(s):
1. Which info is correct? It shouldn't be so complicated to answer,
does this board support VT-d, yes or no?
2. If the error is in the CS-030922 page,
what is being done to confirm the accuracy of the other info on that page?
I'm already overdue to make a purchasing decision,
and need to know if that page is reliable.
The information has been updated. Please check the following link http://www.intel.com/support/motherboards/desktop/sb/CS-030922.htm?wapkw=dz87klt-75k+vt-d http://www.intel.com/support/motherboards/desktop/sb/CS-030922.htm?wapkw=dz87klt-75k+vt-d
