HI
I have intel desktop board dh67bl and i want to buy SSD, Is my motherboard compatible with SSD? how can i install and configure SSD on my PC? If there is any specific model/make that is compatible with my motherboard then can you pls help me with the model/make number. It would be really greatful if you can provide some links/documentation related to this.
Thanks in advance,
Rijesh
Rijesh, you will be able to use an SSD on your DH67BL motherboard. Remember that SSDs that comes in the standard SATA form factor are compatible with Intel® Desktop Boards that support SATA. Just connect the drive to an available SATA port using a standard SATA cable. http://www.intel.com/support/motherboards/desktop/sb/CS-032415.htm?wapkw=(dh67bl+SSD) http://www.intel.com/support/motherboards/desktop/sb/CS-032415.htm?wapkw=(dh67bl+SSD)
The following link contains the list on peripherals tested with Intel® 6 Series Chipset Boards. However, that specific SSD model number is an old device. There are newer models available but they have not been tested by us.http://www.intel.com/support/motherboards/desktop/sb/CS-032984.htm# tested peripheralshttp://www.intel.com/support/motherboards/desktop/sb/CS-032984.htm# tested http://www.intel.com/support/motherboards/desktop/sb/CS-032984.htm# tested
Please advise if any newer SSD models have been tested for DH67BL Motherboard
( http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000007357.html# tested) - This link still shows only two SSD's but these are old and have less capacity. Can you please suggest other models with more capacity(256 GB, 512 GB, 1 TB,......)
Intel80 GBSSD SATA 80GB 2.5' SSD SA2M080G2GCTranscend8 GBTS8GSSD25S-S 2.5 SATA-2 SSD 8GB
Hi Rijesh,
Intel stopped producing and supporting desktop motherboards since 2 years ago, no newer SSDs were tested; however, the motherboard complies with SATA 3.0 and SATA 2.0, so new SSDs with more memory should work without any issue.
Mike C
