Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Intel desktop control center
Would someone please post the entire un-install re- install for the Intel desktop control center software (including registry entries) ?
I installed this Intel software for my D975XBX Motherboard from the Intel site.
I have been unable to open the program because it is not responding in Task Mgr.
I have used Add/Remove programs and windows installer cleanup, reboot and re-installed but no response.
It seems that after staying un-used for a while, the icon disappears and I can't recover it.
I have used it successfully last year.
Why isnt this information in support information ?
Tags (1)
Highlighted
Honored Contributor I
Re: Intel desktop control center
What OS are you using cause IDCC will not work with windows 7 ??
Highlighted
Community Manager
Thank You- Windows XP Home SP3
The download, when opened, will go into uninstall mode if you have installed it before.
I un-installed then re-booted then installed.
No response. Could it be registry entries that have not been un-installed ?
D975XBX Motherboard
Highlighted
Do you use any tune-up programs like Registry Mechanic, or Reg Cure. When I was using XP or Vista I found that you almost had to run them daily to keep your SYS. clean of uninstall JUNK, Funny thing since I went to windows 7 , I rarely have to use Reg Mech. and when I do I get very few bad reg. entries?? P/S I have been using Reg. Mech for years and it works good. Not tring to sell it just stating a fact.
