Intel dx79sr bord bios chip damage now motherboard restarting every moment and i want to make this fault please help me soon Thank you
Please provide more information. What was it doing? What happened? What is it (now) doing? What did you try to do about it? What processor do you have installed? What graphics card do you have installed? What memory to you have installed? Be specific.
Hello dkumara14@gmail.com dkumara14@gmail.com,
Thank you for joining the Intel communities.
To better assist please provide us with more information as N. Scott Pearson has request above.
Ivan
my dear sir please help me.i have Intel Dx79sr Brand new Box with full set motherboard and I installed Xeon E5 2670 CPU,two 4 GB Ram and Nvidea GTX580 Graphic card.I tried every work loke play games and play song and everything My PC stuck loading.after i can not do anything i have one option power off This is the fault after i call seller he said please Bios update.i tried to update bios so came back a fault.my bios update stucked and my motherboard damaged.now it can not power on it is restarting every time?i will show you Youtube link please go that link Next you can see the fault.it is like it.my dear sir please help me what can i do this.Example link at below.https://www.youtube.com/watch?v=PyYf00W6nJI Auto restart p8z68 v pro motherboard. - YouTube
Power off system completely (unplug from wall). Remove CR2032 battery from board. Wait 15 minutes. Reinstall battery and plug back in. See if it now powers up cleanly...
i did every thing but it is not work.i want to return it to company and fix how can i do it
Try installing the RAM on the DIMM closer to the processor and restart the system if the problem persist try on each of the DIMMs or with different RAM.
Double check that your CPU's heatsink/fan is connected properly
Make sure you PSU is connected properly with both the main and aux power connectors firmly attached to the mobo.
Make sure the motherboard is not being shorting out by any other component or the surface.
If the problem persists I suggest contacting http://www.intel.com/content/www/us/en/support/contact-support.html technical support to get a replacement for the motherboard.
Best wishes,
Ivan
dear sir i want to return this item to intel company.how am i do it please help me
You will need to submit a web ticket at the following link in order to get a replacement.
http://www.intel.com/content/www/us/en/support/contact-support.html http://www.intel.com/content/www/us/en/support/contact-support.html
Ivan
