Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11361 Discussions
Intel management Engine says your system does not meet the minimum requirement for installing this software.
aarsh
I have an Intel DH61WW motherboard and Core i3 2100 proc, 2GB Ram , Windows 7 Pro 32 bit , The problem I had was i updated my BIOS from 0020 to 0048 worked fine, then from 0048 to 0099 , After updating to 099 my PC stuck on the bootup screen and was completely unresponsive so somehow got BIOS chip changed PC is working fine but Intel management Engine is showing 0.0.0.0 and Gigabit ethernet adapter is not starting with boot , I suppose this is the problem of IMEI but when I try to install its drivers , I get your system does not meet the minimum requirement for installing this software . Help me pleasee !!!! Current BIOS version after getting the chip changed is 0044.
Kevin_M_Intel
aarsh
Latest chipset drivers are installed and when I tried to install the IMEI given by you in the link I get the same response i.e "Your system does not meet the minimum requirements for installing this software" . No success so far please help me ? Is this a software issue or hardware ?
Kevin_M_Intel
I know this is very basic but did you try with a fresh install of the Operating System?
Kevin m
aarsh
Installed a fresh Windows 7 Ultimate 64 bit , Problem still occurs no success !
Kevin_M_Intel
From my side this is working fine so I recommend you to contact our support Center:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Kevin M
