Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
Intel pch h57 MB RAM compatibility
Community Manager
Hi, i have an Intel pch h57 MB, just wanna to know if its compatible with ddr3 8gb 1333 memories, or what type of memories can support!!! Thanks
Community Manager
I would like to know what is your computer model? Also, the processor model, please bear in mind the memory controller hub is part of the processor, with that information we will be able to pull out memory configuration.
Allan.
Community Manager
Thanks for answer!!! I have an Dell Studio XPS 8100, here I send you the information from the support assist software:
MotherboardManufacturerDell Inc.Product0T568RChipsetIntel PCH H57ePPIDCN0T568R736049CQ01V8BIOSVendorDell Inc.Release Date07/08/2010BIOS Version StringA05ROM Size8.00 MBSMBIOSVersion2.6Controladora RAID SATA de Intel(R) Desktop/Workstation/Server Express ChipsetInterfacePCILocationPCI bus 0, device 31, function 2TypeRAID ControllerClass01h:04h:00hPCI Identification<td class="section_device...
n_scott_pearson
Super User Retired Employee
The short answer to your question is no, 8GB DIMMs are not supported by this processor.
The Intel Core i5-650 processor's memory controller is capable of supporting only 1Gb and 2Gb DRAM technologies and thus is limited to 4GB DIMMs and a maximum of 16GB (2 memory channels X 2 DIMMs per channel).
Sorry,
Community Manager
Oh... but instead the 8 Gb memory, I can replace the 1Gb memories installed with 3x4Gb memories to reach the limit of 16Gb right? Thanks again for your help!!!
n_scott_pearson
Just in case that wasn't a typo, I will restate - You can replace all of the DIMMs that you currently have with four 4GB DIMMs, provided that these DIMMs all utilize 2Gb memory technology and that these DIMMs have identical specifications (i.e. same voltage (1.5V), same wait-states, etc.). Many DIMM manufacturers offer packages containing matched pairs of DIMMs; there are always a good idea. I also recommend that you purchase native 1333MHz DIMMs; you may have compatibility issues with faster DIMMs.
The usual caveats apply. While I can answer for the Intel Desktop Board products, there may be other or differing requirements for boards produced by other manufacturers. You should check their website for more information...
Hope this helps,
n_scott_pearson
If you can find a package providing four matched DIMMs, this is even better...S
Community Manager
Scott has provided great information, you need to check with your Dell for supported memory configuration.
Processor specs linked below and attach to this thread.
http://ark.intel.com/products/43546/Intel-Core-i5-650-Processor-4M-Cache-3_20-GHz http://ark.intel.com/products/43546/Intel-Core-i5-650-Processor-4M-Cache-3_20-GHz
Allan.
