Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
Intel processor pression slot
MariusFla
Someone can please inform me where can I found the information below on CPU model specification datasheet:
How many times are recomended take and put the processor on socket ?
Thanks for advance.
Marius
AlHill
You are asking how many times a processor can be inserted and removed from the cpu socket?  Well, first, which socket?  Which processor?
You will not find that kind of answer here.  You will have to work with one of the Intel support engineers, and you will have to have a NDA, if that information is available.
An Intel support engineer will be by shortly and will assist you.
Doc
