Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
Intel rapid storage, RAID5 on 3 disc, won't stop rebuilding on win7 @ thinkstation D30
HLiu38
Dear All:
I thought RAID should be safe... but I was wrong...
I have a thinkstation D30, installed 3 3T seagate sata drive, configured it to RAID5 and started working on it, I had it less than 6 month
started last Friday the system keeps telling me files cannot be saved due to IO issue, I then reboot the machine, intel rapid storage stated two disc failed, but I can still see the disc content... I then marked the discs as normal (I would not assume they are bad only after several month of light usage).... the disc started rebuilding...
however it kept doing that, each and every time it gets to around 60% it restarts from 0%... and the disc is no longer viewable... though on disc management it is shown as healthy and on line
Anyone help here! many many thanks!
On another line, I have a 12T Lacie external raid array, it also experienced issue as to not accessible, but it was fixed by power down and up... RAID does not seem to be a good solution if you want your data to be safe ...
Allan_J_Intel1
Thanks for joining the Chipset community.
I have checked specifications of Thinkstation D30 and it seems to integrate an Intel server chipset. The issue you described is directly related to your computer manufacturer.
For contact information, please hit this link: http://shop.lenovo.com/us/en/landingpage/contact/ Official Lenovo Contact Us Page | Lenovo US
Allan.
HLiu38
hi, Allan:
Thanks for your reply, could you be more specific? Is there known confliction between LENOVO and intel products?
I just found out the volume is labeled as degraded, but not individual discs..., I am attaching a screenshot, and it seems the only option is to delete volume, so what is going on?
Hao
Allan_J_Intel1
The support for your product (Lenovo) with Intel server chipset is not available through Intel. Issues with Intel® Rapid Storage are handled by Lenovo.
Allan.
HLiu38
Thanks again, but after installing their software... I still seeing the same thing, all 3 discs show as healthy but the volume marked as degraded with no option to set it back to normal -- I was able to do that before but the rebuild never finishes... this is truly annoying since the window's storage management show a 6T disc as healthy too... just not accessible
Allan_J_Intel1
Please address this issue contacting Lenovo at http://shop.lenovo.com/us/en/landingpage/contact/ Official Lenovo Contact Us Page | Lenovo US
Allan.
