Community
cancel
Showing results for
Search instead for
Did you mean:
JLebe1
Is the DP55WB compatible with the GTX 970?
Hi
I am gonna buy a GTX 970 for my system (i5 + DP55WB) will it work with this motherboard?
Allan_J_Intel1
Thanks for joining the Desktop Board community.
Intel does not have a list of tested video cards for your motherboard model; however, you need to check this type of compatibility with the video card manufacturer, as long as the video card is PCI Express X16 2.0 revision, it should work.
http://downloadmirror.intel.com/18131/eng/DP55WB_TechProdSpec.pdf http://downloadmirror.intel.com/18131/eng/DP55WB_TechProdSpec.pdf
Allan.
JLebe1
It's a 3.0 16x like my actual Geforce 650ti Boost
Allan_J_Intel1
In that case, the video card might work at 2.0 revision. Please check with Nvidia for more compatibility information: http://www.nvidia.com/page/support.html Support | NVIDIA
Allan.
