Intel® Desktop Boards
Peer-to-peer support only
11476 Discussions
Is there any UEFI management tool or commands that I can run in a Command line interface to change or view the different settings in UEFI?
AGhos3
I am using the intel h310 chipset motherboard. I am looking for a UEFI management tool or commands that I can run in a command line interface to change or view the different settings in UEFI, like the following:
  • Change the Boot Order
  • Load UEFI Setup Defaults
  • Remove a UEFI Password
  • Create a UEFI Password
  • Change the Date and Time
  • Change Hard Drive Settings
  • Change CD/DVD/BD Drive Settings
  • View Amount of Memory Installed
  • Change the Boot Up NumLock Status
  • Enable or Disable the Computer Logo
  • Enable or Disable the Quick Power On Self Test (POST)
  • Enable or Disable the CPU Internal Cache
  • Enable or Disable the Caching of UEFI
  • Change CPU Settings
  • Change Memory Settings
  • Change System Voltages
  • Enable or Disable RAID
  • Enable or Disable Onboard USB
  • Enable or Disable Onboard IEEE1394
  • Enable or Disable Onboard Audio
  • Enable or Disable Onboard Serial/Parallel Ports
  • Enable or Disable ACPI
  • Change the ACPI Suspend Type
  • Change the Power Button Function
  • Change Power-on Settings
  • Change Which Display is Initialized First on Multi-Display Setups
  • Reset Extended System Configuration Data (ESCD)
  • Change Fan Speed Settings
  • View CPU and System Temperatures
  • View Fan Speeds
  • View System Voltages
n_scott_pearson
Super User Retired Employee
Sorry, this forum is for the support of Intel's Desktop Board products. It is NOT for the support of motherboards from other manufacturers.
Intel Customer Support (@MaryT_Intel​), please move this query to the chipset forum.
AGhos3
I was not able to find any option for Chipset when posting my question.
n_scott_pearson
You are right! @MaryT_Intel​: what happened to this forum; was it never set up?
As a starting point for EFI Shell usage, check out this page: https://software.intel.com/en-us/articles/efi-shells-and-scripting.
Hope this helps,
AGhos3
The document says it's for windows XP. Anything for Windows 10?
n_scott_pearson
Huh? No, no, no! EFI Shell is not something you run under an O/S; it is independently booted. It's not really the case (and BIOS engineers will take a fit over me saying so), but you could think of EFI Shell as being a (in some cases, built-in) replacement for DOS. The examples you see mention Windows XP simply because this article was written way back in 2008. Again, I mentioned this as a starting point for learning about what you can (and can't) do in EFI shell...
