Community
cancel
Showing results for
Search instead for
Did you mean:
KCheu4
Issues with 32GB(31.8GB usable) ram
Jump to solution
I have recently built my PC with the following setup:
Intel 4771
DZ87KLT-75K
32GB ( 4 x 8G Team Xtreem 1600 XMP)
Plextor M5Pro 256GB
Colourful Nvidia GTS450
Antec HCG520M
Windows 7 Ultimate 64bit
I am having an issue that I cannot get the remaining 204MB back in the Resources Monitor, it may sounds nothing when using such a large amount of memory. But I do like to get them back in my hands.
I have tried :
1. Fresh installation of the OS.
2. Updated to the latest BIOS.
3. Latest driver from Intel site.
4. Reposition of rams.
5. Manually set the rams with the manufacture settings.
6. Reset the BIOS.
No matter how much memory I tried, from 8GB,16GB,24GB to 32GB. It still ate me 204MB from the memory, the BIOS and Resources Monitor can recognize all memories,1024x32.
***UPLOAD***
Can anyone help me to get them back? I saw others with similar systems are fine with that 32GB memories fully used. Thank You!
Karson
Tags (1)
Stephen
Valued Contributor I
The new BIOS 0346 Fixes This Issue
ZAgha
New Contributor II
There is a Hardware reserved : Memory that is reserved for use by the BIOS and some drivers for other peripherals "as per MS".
It's normal to have this.
Stephen
That's Normal Its Know As System Reserve For Whatever Reason, Just So You Know Even If It Indicates Full 32GB You Can Never Use The Whole Of It, There Is Always System Reserve.
Yo Mean Like This Even Mine Shows That
My System Specification
Intel Desktop Board DZ87KLT-75K
Intel Core i7-4770K
Corsair Vengeance LP 32GB (4 x 8GB @ 1600MHz C9, XMP 1.3)
EVGA GTX 770 SC 2GB ACX
Seasonic X660 (660W)
Note I Had the RAM on a DZ68BC, MSI Z87 Based Board, EVGA Z77 FTW Before and Still Showed Same Thing, So This Is Perfectly Normal.
Stephen
KCheu4
Thanks a lot! Just done with my long trip, finally can back on track using it for editing!
Here I used the latest 446, it is fixed!! Cheers
Silvia_L_Intel1
I'm glad to know you were able to solve your issue!
KCheu4
Even the Technical sheet didn't mention about the fix, but it works, thanks for listening and quick response!
