Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
It turns out port 664 is being used by Intel AMT, however it supports SSLv2/3 etc; Can you get SSLv2/3 and RC4 Cipher suites disabled, and only use TLS1.1/1,2 for AMT?
Community Manager
n_scott_pearson
Super User Retired Employee
For AMT issues, you will get better support here: https://bizsupport.intel.com https://bizsupport.intel.com You will need to register for an account when you get there.
Hope this helps,
n_scott_pearson
Hope this helps,
Community Manager
Hello Valente:
I just wanted to let you know that the answer provided by N. Scott Pearson is the correct one; and in order to get support for Intel® AMT the best thing to do will be to get in contact directly with the department that supports that feature by using the following link:
And N. Scott Pearson mentioned, you just need to register for an account to be able to get support from them.
Alberto
