Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
LED backlight of LCD panel with D525MWV
i want to connect MB intel D525MWV to LCD Panel (LP156WH4-TLA1) the problem is this LCD panel is LED backlight how i can connect LED backlight to mother board connector (inverter or LVDS) ??
Thank you
Tags (1)
Highlighted
Community Manager
Hello Mostafa,
I understand that you wish to enable the LVDS on the Intel(R) Desktop Board D525MWV.
Unfortunately for System Electro Magnetic Compatibility (EMC) certification them motherboards do not have enabled the LVDS port and the information on how to enable it will be provided to system manufacturers that will take the necessary precautions to comply with the EMC standards.
If you are looking to enable this I recommend you to contact your local technical support to request for the information.
Here you can find your local contact information:
http://www.intel.com/p/en_US/support/contact/phone?redirector_count=1& http://www.intel.com/p/en_US/support/contact/phone?redirector_count=1&
Regards.
PV
