Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
LGA 1155 contact at the number AN 12 (SB_DQS# [2])
I have an Intel DQ67SW motherboard with the processor LGA 1155 plug. In this plug contact at the number AN 12 (SB_DQS# [2]) is broken soft. According to the technical documentation, the specified contact is responsible for an information signal of DDR3 Channel B. Question: if to set the processor, whether there will be the partial operability of device,
Tags (1)
Highlighted
Community Manager
We would like to inform you that any kind of physical damage will prevent the motherboard to work properly. We do not recommend using components with broken parts or similar since it could cause damage to other components on your system and will void the warranty on your Intel(R) product.
