Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
LPT1 Address in D2500HN
DSimp2
Hi all,
I plan to use the Intel D2500HN motherboard in order to run some old control software that uses the parallel port interface, under winXP. The problem is that the software only works when the LPT1 address is mapped in the typical LPT1 address: 0x378. Could you please confirm me whether this motherboard will fit my needs?
Silvia_L_Intel1
Mailinator2,
I'm going to research on this since this information is not available on the TPS.
Regards.
DSimp2
DSimp2
Are there news about this?
Cheers.
Silvia_L_Intel1
Mailinator2, it looks like the LPT address does use the standard address 0x378 as you said. So this motherboard should work for you.
