Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
Looking for Compatible Northbridge Heatsink for Intel DX58SO Motherboard
Community Manager
Hello all!
I'm looking for a Northbridge X58 Chipset heatsink that's compatible with my Intel DX58SO motherboard. I will be overclocking so something with stock or better heat dissipation is desired. I no longer have the stock heatsink for the northbridge (don't ask how I lost it).
I've found a couple different heatsinks but I don't know if they're compatible with the DX58SO. The mounting holes on this board seem farther apart than what I see on other boards. I tried taking some measurements of the four mounting holes and this is what I got:
Horizontal Holes: 66.675mm apart
Vertical Holes: 47.625mm apart
Diagonal Holes: 80.9625mm apart
Here are two of the heatsink/fans combos I was considering:
-Enzotech Cnb-r1 and 40mmx40mm fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835708002&Tpk=cnb-r1&IsVirtualParent=1 http://www.newegg.com/Product/Product.aspx?Item=N82E16835708002&Tpk=cnb-r1&IsVirtualParent=1 and http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=20870 http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=20870
SilenX IXN-40C Copper Chipset Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835226019 http://www.newegg.com/Product/Product.aspx?Item=N82E16835226019
I'm struggling to find a new chipset heatsink for this motherboard. Can anyone help me figure out if the above heatsinks will be compatible with the Intel DX58SO Northbridge? And if none of the above are compatible, do you know of any that are?
Silvia_L_Intel1
Hello Madison,
We have our own FAN kit for the DX58SO motherboard, the part number is E43121-001.
Silvia_L_Intel1
Hello Madison,
