Intel MB DZ77GA-70K - intel i53570k - both just out of the box (Stored over a year). GSkill F3-12800CL9D-8GBRL memory (GSkill says compatible) . Put together system yesterday and on start get 3 beeps {memory error} and code 41 on the LCD readout. Tried swapping modules, and different slots. Tried using Corsair CMX 16GX3M2A1600C11 with same results. Reseated CPU. Any suggestions?
Does it boot with a single memory stick in DIMM 1?
- If yes, enter the BIOS and verify the memory configuration is correct. Check the BIOS version and update incrementally as needed.
- If no, try using a memory from the compatibility list or that meets all the requirements.
http://www.intel.com/support/motherboards/desktop/dz77ga-70K/sb/CS-033219.htm Intel® Desktop Board DZ77GA-70K — System Memory
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS Update
