Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
Memory controller and RAM
AVyno
Can a defective memory controller on the CPU damage the RAM? I have a core I7 2600k not oc'd and 2x4Gb DDR3 Dual-Channel. Since a few weeks my RAM module in Channel 2 or B gets broken / faulty when usiing Dual-Channel. Channel A works well in Single-Channel mode. I've already had the third kit broken. My System ran fine for almost 2 years with the following setup:
Mainboard: ASRock Fatal1ty Z68 Professional Gen3
RAM: Corsair DDR3 1600 1,65V running at 1,5 volt
CPU: I7 2600k not overclocked
GPU: GTX580 stock clock
PSU: 1200 watts
Sadly I do not have any other means/pc's of testing the cpu.
If it's possible that the memory controller is faulty I'd like to replace the CPU.
I appreciate any help/information.
http://www.google.de/search?q=means http://www.youtube.com/results?search_query=means http://www.google.de/search?hl=de&btnI=I'm+Feeling+Lucky&q=means+wikipedia MeansMean (average), a term used in mathematics and statistics http://duckduckgo.com/?q=means&t=ff
Kevin_M_Intel
Hi LEXXIUS,
I am really to hear you are having problems with your system but let me help you.
When the memory controller inside the processor is damaged the most common behavior in the system is to get errors/beep codes since the system may not recognize the RAM properly.
From our side, I recommend you running the Intel® Processor Diagnostic Tool. This is a software that test every internal component in the processor and In the case there is something wrong on it, will be displayed.
Here is the download link:
32 bit:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19791 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19791
64 Bit:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19792 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19792
I also recommend you updating the BIOS in your system to the latest provided by ASRock. Here is their support site:
http://www.asrock.com/ http://www.asrock.com/
AVyno
The test had a full pass. Does it matter if i run my memory in dual channel or single channel for the IMC test? As of now I have one module in channel 1, as i assume dual-channel or 2nd channel corrupts the modules.
Kevin_M_Intel
The memory test will diagnose the ram stick connected to the system so if you connect both, the program will test dual channel. There could be a problem with the memory controller when testing dual channel configuration so my best recommendation is to contact the motherboard manufacture for them to test it or replace it if necessary.
AVyno
Also I would like to know if I can run RAM with any voltage on Sandy Bridge or should I stick to 1.5V? I undervolted my RAM from 1.65V to 1.5V this whole time.
It's just that I've read so many different opinions on so many forums...
Kevin_M_Intel
At this point all Intel® processors are capable of running memory at 1.5v only. Now, you can try if you want running at 1.65v but we do not recommend that since the processor can be affected or the performance in your system.
From our side i can confirm that the correct speed for a Sandy Bridge is a memory up to 1333MHz running at 1.5v.
Here you can check the processor specifications:
http://ark.intel.com/products/52214/Intel-Core-i7-2600K-Processor-8M-Cache-up-to-3_80-GHz?q=2600K http://ark.intel.com/products/52214/Intel-Core-i7-2600K-Processor-8M-Cache-up-to-3_80-GHz?q=2600K
