O HD e os pen drives funcionam normalmente como boot em outras Main baords, porém não consigo dar boot em nada, e nem atualizar a BIOS por conta desses erros, alguma ajuda?
Has this board worked previously?
Remove all removable drives, including all CD/DVD drives.
Doc
Sim, ela já funcionou anteriormente, eu não uso driver de DVD/CD, é pra eu dar BOOT nela sem nenhum driver, inclusive o HD, certo?
Not if you use a DVD/CD, just the mere presence of a failed DVD/CD drive in the system can cause boot problems. Have only the HD in the system and try booting from that.
Doc
I don't use a DVD/CD device, the BIOS system don't no recognize the HD, pen drives are recognized, but I can't boot the system, BIOS post error, post error B8 when I try to boot from any storage
I never install a CD/DVD device in this mainboard, and I can't update the BIOS, because I can't boot from a flash drive, even though everything is set to boot from the flash drive in the BIOS
B8 is complaining about "Resetting removable media".
What BIOS version do you have, and have you tried recovery mode?
Doc
Yes, i know about this
The BIOS version is out to date, this version of BIOS don't have recovery mode, only boot by bios and clean jcmos
for this reason i want to update BIOS with pen drives, but don't work
Your board does have recovery mode.
Look here on page 51 table 24, and on page 61 section 3.7
https://www.intel.com/Assets/PDF/prodspec/DP35DP-tps.pdf
Look here for recovery instructions:
https://www.intel.com/content/www/us/en/support/articles/000005630/boards-and-kits.html
Again, what bios DID the board have, and what bios do you have on you usb stick? This is very important!
Doc
Vou fazer o que você indicou no post em relação ao recovery da bios, irei tentar atualizar para a última versão da BIOS disponível para essa placa mãe, aguarde uma resposta minha.
But, BEFORE you do that, what is the current bios and what bios do you have on the usb stick?
VERY IMPORTANT!
Doc
Also, for boards this old, make sure that you are: (a) NOT using a USB 3.0 flash drive and (b) NOT using a USB 2.0 flash drive larger that 8GB.
