Intel® Desktop Boards
Peer-to-peer support only
11480 Discussions
Modelo de Placa que acepte Procesador core i9 , Ram 128 gigas y acepte RAID
MBURG9
AlHill
Intel no longer makes desktop boards.
You can find information on processors here:
https://www.intel.com/content/www/us/en/products/processors/core.html
Once you find a processor you like, you can look up compatible boards here:
http://processormatch.intel.com/Processors/Index/
Doc
MBURG9
n_scott_pearson
Super User Retired Employee
Intel RST, which implements RAID support, is provided in *all* Intel chipsets. The processor in use doesn't matter.
Remember that, before installing your O/S, you should go into BIOS Setup and change the Chipset SATA Mode from AHCI to RAID. Again, you should do this before installing your O/S.
Hope this helps,
