Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Monitor Displays "No Signal" even CPU/M.Board is Running
ASuth
Dear Forum,
My Monitor is AOC LED monitor, it works fine till date but from few days my monitor shows "No Signal" after 15-20min of working. RAM/Hard Disk and Monitor working fine but after sometimes CPU is neither restart or shut down nor showing processor blinking light, it require to power off from source. Few days before I installed 2GM DDR2 RAM in addition to 1GB DDR2 RAM, I tried replacing each other and removing one by one. I also tried to clean CPU by blowing air to make dust free. Also I replaced new VGA cable by old one. Monitor works fine but he problem persist after so many efforts.
Is it due to CMOS battery or Motherboard problem..??
Please suggest the way forward to solve this problem.
Ashok
Silvia_L_Intel1
Hello Ashok, thanks a lot for posting your inquire at Intel communities.
Would you please provide me your system information?
  • Motherboard model number:
  • Processor:
  • Memory information:
  • BIOS version:
ASuth
Dear Sylvia,
Please refer below info;
Motherboard
Manufacturer Intel Corporation
Model D945GCPE (LGA 775)
Chipset Vendor Intel
Chipset Model i945G
Chipset Revision A2
Southbridge Vendor Intel
Southbridge Model 82801GB (ICH7/R)
Southbridge Revision A1
System Temperature 42 °C
BIOS
Brand Intel Corp.
Version PE94510M.86A.0050.2007.0710.1559
Date 10-07-2007
Voltage
CMOS BATTERY 3.248 V
PCI Data
Slot PCI
Slot Type PCI
Slot Usage Available
Bus Width 32 bit
Slot Designation PCI SLOT 1
Characteristics 3.3V, PME, SMBus
Slot Number 0
Slot PCI
Slot Type PCI
Bus Width 32 bit
Slot Designation PCI SLOT 2
Slot Number 1
CPU
Intel Pentium E2160
Cores 2
Threads 2
Name Intel Pentium E2160
Code Name Conroe
Package Socket 775 LGA
Technology 65nm
Specification Intel Pentium Dual CPU E2160 @ 1.80GHz
Family 6
Extended Family 6
Model F
Extended Model F
Stepping D
Revision M0
Instructions MMX, SSE, SSE2, SSE3, SSSE3, Intel 64, NX
Virtualization Not supported
Hyperthreading Not supported
Fan Speed 1159 RPM
Bus Speed 199.5 MHz
Rated Bus Speed 798.0 MHz
Stock Core Speed 1800 MHz
Stock Bus Speed 200 MHz
Average Temperature 50 °C
Caches
L1 Data Cache Size 2 x 32 KBytes
L1 Instructions Cache Size 2 x 32 KBytes
L2 Unified Cache Size 1024 KBytes
RAM
Memory slots
Total memory slots 2
Used memory slots 1
Free memory slots 1
Memory
Type DDR2
Size 2048 MBytes
Channels # Single
DRAM Frequency 332.5 MHz
CAS# Latency (CL) 5 clocks
RAS# to CAS# Delay (tRCD) 5 clocks
RAS# Precharge (tRP) 5 clocks
Cycle Time (tRAS) 15 clocks
Bank Cycle Time (tRC) 21 clocks
Physical Memory
Memory Usage 65 %
Total Physical 1.99 GB
Available Physical 695 MB
Total Virtual 3.98 GB
Available Virtual 2.47 GB
SPD
Number Of SPD Modules 1
Slot # 1
Type DDR2
Size 2048 MBytes
Manufacturer Kingston
Max Bandwidth PC2-6400 (400 MHz)
Part Number 2G-UDIMM
Serial Number 7E24FAC2
Week/year 15 / 14
BIOS Version:
As provided in Motherboard info..
AGAIN, I'm PROVIDING "DxDiag Report"
System Information
Time of this report: 9/7/2014, 13:01:44
Machine name: ASHOK-PC
Operating System: Windows 7 Home Basic 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
Language: English (Regional Setting: English)
System Manufacturer: INTEL_
System Model: D945GCR_
BIOS: Default System BIOS
Processor: Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz (2 CPUs), ~1.8GHz
Memory: 2048MB RAM
Available OS Memory: 2038MB RAM
Page File: 1317MB used, 2757MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) 82945G Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Intel(R) 82945G Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2772&SUBSYS_D6078086&REV_02
Display Memory: 256 MB
Dedicated Memory: 0 MB
Shared Memory: 256 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor Name: Generic Non-PnP Monitor
Monitor Model: unknown
Monitor Id:
Native Mode: unknown
Output Type: HD15
Driver Name: igdumd64.dll
Driver File Version: 8.14.0010.1930 (English)
Driver Version: 8.15.10.1930
DDI Version: 9Ex
Driver Model: WDDM 1.0
Driver Attributes: Final Retail
Driver Date/Size: 9/23/2009 19:22:58, 5472256 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6432-11CF-BCE4-0DF6A3C2C535}
Silvia_L_Intel1
Ashok, thanks for the information.
The current BIOS version of your board is 0050. There are 7 newer versions that we can try to install in order to find out if this could solve the issue.
It is important to tell you that going straight to the latest version shouldn't be a problem, technically speaking. However based on experience, there is always chance.
I would recommend you to install the at least 3 BIOS version and then check if the behavior persisted.
You can also check the BIOS Update Release Notes at this URL. You will be able to see the fixes and features included on each version. http://downloadmirror.intel.com/17241/eng/PE_0069_ReleaseNotes.pdf http://downloadmirror.intel.com/17241/eng/PE_0069_ReleaseNotes.pdf
These are some important versions you could flash on your system.
We provide an application that is called Intel® Processor Diagnostics Tool. You can run this application and it will diagnose the processor components and will generate a result. I suggest you running this in to discard any possible issues with the processor (hardware).
Please use minimum configuration while running this test
You can get this from the following link:
If operating system is 32 bit based: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19791&lang=eng&OSVersion=Windows%208%... Intel® Download Center
If operating system is 64 bit based: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19792&lang=eng&OSVersion=Windows%208%... Intel® Download Center
