Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
Mother Board DP35DP with P35 Express Chipset
Community Manager
In 2008 I installed Mother Board DP35DP with P35 Express Chipset for a desk set. It appears to run a bit slow at times and I was looking to see if there is any changes required for the Bios or hardware. I am currently running the Microsoft 10 Pro operating system. What is the current support for this hardware and is there any suggestion for changes in motherboard or chipset. The computer is used for personal and business support only.
Sincerely,
Ed Walsh
n_scott_pearson
Super User Retired Employee
I am going to be brutally frank. This board is well beyond its expected lifetime and its components (including processor) are well beyond their Mean-Time-Between-Failures (MTBF) specifications. This hardware is not properly supported by Windows 10 and some of the slowness is the result of its drivers running in compatibility mode. My recommendation is that you recycle this system and purchase a more-modern system to replace it. Many of the latest generation Atom processors will likely outperform the processor that you have in this board.
Sorry I didn't have a better answer, but this is reality...
Community Manager
edwalsh ,
Correct, Scott's answer is accurate, the compatibility of the system with Windows 10* is probably causing the slowness in your Intel® Desktop Board DP35DP (Launch date: Q3'07).
You may also want to confirm that you are not experiencing any hardware failures (Memory, HDD, PSU).
Here you can find compatible OS' for your board: http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005640.html http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005640.html
Here are the minimum requirements from Microsoft for Windows 10*: https://www.microsoft.com/en-us/windows/windows-10-specifications# sysreqs Windows 10 Specifications & System Requirements | Microsoft
Esteban C.
