Intel® Desktop Boards
Peer-to-peer support only
11480 Discussions
Motherboard DG965SS can't use microphone with windows 7
RErar
Motherboard DG965SS can't use microphone with windows 7 is the issue I can't solve, audio works well but there is no way I could find to use a microphone with this system, which previously had windows xp sp3 and everything was working fine.
Windows 7 has been installed for a long time now but I never had to worry about using a mic until recently..
There is no driver at all for microphone at INTEL's website.
I even contacted INTEL's Support and they admit there is nothing they can help me with, they even provided this communities' site to try and post/obtain further help to/from the community.
Thanks for any support I can get from the community.
DG965SS, 1.5 gb 500gb sata drive. Windows 7 SP1
System Details:
CPU-Z TXT Report
Binaries
CPU-Z version 1.85.0.x32
Processors
Number of sockets 1
Number of threads 2
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Core 1 (ID 1)
-- Thread 1 1
Timers
ACPI timer 3.580 MHz
Perf timer 2.602 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Pentium D 805
Codename SmithField
Specification Intel(R) Pentium(R) D CPU 2.66GHz
Package (platform ID) Socket 775 LGA (0x4)
CPUID F.4.7
Extended CPUID F.4
Core Stepping B0
Technology 90 nm
Core Speed 2663.9 MHz
Multiplier x Bus Speed 20.0 x 133.2 MHz
Base frequency (cores) 133.2 MHz
Base frequency (ext.) 133.2 MHz
Rated Bus speed 532.8 MHz
Stock frequency 2666 MHz
Instructions sets MMX, SSE, SSE2, SSE3, EM64T
Microcode Revision 0x3
L1 Data cache 2 x 16 KBytes, 8-way set associative, 64-byte line size
Trace cache 2 x 12 Kuops, 8-way set associative
L2 cache 2 x 1024 KBytes, 8-way set associative, 64-byte line size
Max CPUID level 00000005h
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 16 KB, 1 thread(s)
Cache descriptor Level 2, U, 1 MB, 1 thread(s)
Cache descriptor Level 1, T, 12 KB, 1 thread(s)
FID/VID Control no
IBRS not supported
IBPB not supported
STIBP not supported
RDCL_NO no
IBRS_ALL not supported
Clock Speed 0 2663.90 MHz (Core # 0)
Clock Speed 1 2663.90 MHz (Core # 1)
Core 0 max ratio (effective) 20.0
Core 1 max ratio (effective) 20.0
BIOS
UEFI Yes
Chipset
Northbridge Intel P965/G965 rev. C2
Southbridge Intel 82801HB/HR (ICH8/R) rev. B0
Memory Type DDR2
Memory Size 1536 MBytes
Host Bridge 0x29A0
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR2
Module format Regular UDIMM
Manufacturer (ID) (0000000000000000000000)
Size 256 MBytes
Max bandwidth PC2-4300 (266 MHz)
Part number
Number of banks 4
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC # 1 3.0-3-3-9-12 @ 200 MHz
JEDEC # 2 4.0-4-4-12-16 @ 266 MHz
JEDEC # 3 5.0-4-4-12-16 @ 266 MHz
DIMM # 2
SMBus address 0x51
Memory type DDR2
Manufacturer (ID) (FFFFFFFFFFFFFFFF000000)
Size 512 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number
Serial number FFFFFFFF
Manufacturing date Week 165/Year 165
Number of banks 4
Data width 64 bits
Correction None
EPP no
XMP no
AMP no
JEDEC # 3 5.0-5-5-15-20 @ 333 MHz
DIMM # 3
SMBus address 0x52
Memory type DDR2
Size 256 MBytes
Part number
Number of banks 4
Data width 64 bits
Correction None
EPP no
XMP no
AMP no
DIMM # 4
SMBus address 0x53
Memory type DDR2
Manufacturer (ID) NovaTech Solutions (7F7F7F7F7F940000000000)
Size 512 MBytes
Part number NA2D512M30D
Number of banks 4
Data width 64 bits
Correction None
EPP no
XMP no
AMP no
JEDEC # 1 3.0-3-3-9-11 @ 200 MHz
JEDEC # 2 4.0-4-4-12-15 @ 266 MHz
JEDEC # 3 5.0-5-5-15-18 @ 333 MHz
DMI
DMI Processor
manufacturer Intel(R) Corporation
model Intel(R) Pentium(R) D CPU 2.66GHz
clock speed 2666.0 MHz
FSB speed 133.0 MHz
multiplier 20.0x
DMI BIOS
n_scott_pearson
Super User Retired Employee
There is no separate microphone driver. All you need to install is the IDT 92XX Audio driver; it provides support for the microphone.
You plug the microphone into the microphone port on the rear I/O panel (or front panel connectors if your chassis supports them and its cable is connected to the front panel connector on the board), configure its operation in the control panel (though I can't remember if this pops up automatically when the microphone is plugged in) and it should work.
Hope this helps,
RErar
Hi Scott thanks for your reply, I am downloading the drivers you mentioned, but those drivers seem good up until vista, 32 or 64 bit.
There is no mention to any further upwards system.
Still, after downloading, I opened the file and proceeded to install it..
It seems to have corrected the issue, I'll have it under test for a while just to see if I can get the volume a little higher as it used to be before, at least now I can see the speaker and microphone (and also the line-in) menues, and I can adjust the values.
Thank you.
