Hola, buenos días, tengo el siguiente problema, tengo una PC con una MB Intel DX58OG estaba funcionando perfectamente, quise mejorar mi tarjeta gráfica instalando una nueva y mejor, al hacerlo, la gran sorpresa, no me inicia el PC se queda en la pantalla con la imagen de Intel, presione F2 para el BIOS Setting y se ve también el código A5, de ahí no pasa, he presionado la tecla F2 y no hace nada, me podrian ayudar, muchas gracias...
Hi joseapl,
Let me know the brand name and model of graphics card, processor model and model of the memories.
Mike C
Hi, Mike C.
Thank You for your help.
Graphics Card: XFX R9 280X
Processor Model: Intel I7 940
Memories: Kingston HyperX Genesis KHX1600C9D3
In the Monitor the code si A5
In the POST Code Display (MB) Eb
I have attached pictures to you, I really have never happened before, I appreciate your help,
This is becoming a more and more common occurrence. Unfortunately, it is likely a compatibility issue. This motherboard is 5 generations and 6 years old. The graphics card has expectations that the board and its BIOS are unable to meet.
One thing you can try is enabling UEFI. You will have to put back the old graphics card to do this. Unfortunately, if it works, you will likely have to reinstall Windows.
Sorry I don't have a better answer...
...Scott
Hi joseapl,
The graphics card comes with bus type PCIe 3.0 and motherboard has PCIe 2.0; additionally the processor supports memories of DDR3 at 800 / 1066Mhz while Kingston memories run at 1600MHz. The Intel® Core™ i7-940 belongs to the first generation Core™ processors.
http://ark.intel.com/products/37148/Intel-Core-i7-940-Processor-8M-Cache-2_93-GHz-4_80-GTs-Intel-QPI Intel® Core™ i7-940 Processor (8M Cache, 2.93 GHz, 4.80 GT/s Intel® QPI) Specifications
It is necessary to use an older graphics card with this motherboard.
Mike C
