Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
My Intel DH67CL motherboard is not giving display every time when I switch ON my CPU.
DPate11
23rd September' 2016.
Subject : My Intel DH67CL motherboard is not giving display every time when I switch ON my CPU.
Attachments : 5 JPG files.
Dear all,
I have,
Intel DH67CL motherboard (Version : AAG10212-210. BIOS version : BLH6710H.86A.0160.2012.1204.1156).
Intel Core i3-2120 processor.
Intel Management Engine firmware : 8.0.13.1502 (Its showing in BIOS).
4GB DDR3 1333Mhz RAM installed in DIMM1 + 4GB DDR3 1333Mhz RAM installed in DIMM2 = Total 8GB RAM.
Dell S2340L LED IPS 23" HDMI full HD (1920*1080p) monitor.
Western Digital 1TB SATA HDD with Windows 7 Ultimate 32 bit O/S installed in it & connected in SATA0 port on Intel DH67CL motherboard.
Western Digital 500GB SATA HDD with Windows 8.1 Enterprise 64 bit O/S installed in it & connected in SATA1 port on Intel DH67CL motherboard.
Samsung SATA DVD writter connected in SATA2 port on Intel DH67CL motherboard.
8GB Transcend make USB pendrive.
USB K/B + USB optical mouse.
PC + monitor connected with APC UPS.
Please see below file name attachment for booting sequence & HDD details :
"Booting sequence & HDD details.JPG"
Be note at here :
Intel DH67CL motherboard BIOS configuration jumper position status :
1-2 = Normal
2-3 = Configuration
No jumper = Recovery
Please see below file name attachment for this :
"Intel DH67CL BIOS jumper layout.JPG"
From last few days I am facing below mentioned problem randomly, please guide me about it that why its happening & what will be the technical solution.
Step 01 I am doing :
Problem I am facing : My Intel DH67CL motherboard is not giving display every time when I switch ON my CPU. At the same time, CPU cooling fan & cabinet cooling fan, SMPS (power supply) cooling fan are moving, LED of USB optical mouse is ON but no LED of "Num Lock" & "Caps Lock" even I press these 2 keys one by one on keyboard, both SATA HDD are spinning, DVD trey in-out is also working OK if I press DVD writter's switch, no LED blink on USB pendrive. Multiple times I switch OFF & re-switch ON the CPU but my Intel DH67CL motherboard is not giving display every time & remaining hardwares' symptoms are same as I mentioned above. Randomly & very rarely my Intel DH67CL motherboard will give display (and then boot also either from any O/S which I choose) after so many times of unsuccessful trial of switch OFF & re-switch ON of the CPU.
No beep noise is coming during no display though I set "Enable" option in BIOS for "No Video Detected Error Beeps".
If I am working either in Windows 7 Ultimate 32 bit O/S or in Windows 8.1 Enterprise 64 bit O/S & after finishing my work, when I am either doing hibernate or restart or shutdown the PC, there is no guarantee that when I next time switch ON the CPU whether my Intel DH67CL motherboard will give display or not !!!!!
I can't understand why its happening ?
Step 02 I am doing :
As there is no display coming as per above "Step 01", now I switch OFF the CUP. Now I remove BIOS configuration jumper from 1-2 position & insert in 2-3 position, now I switch ON the CPU, then my Intel DH67CL motherboard is giving BIOS display every time !!!!! Here its gives 1st message like "Clear BIOS Passwords - - This will clear BIOS Supervisor and User Passwords. Continue ? (Y/N) ". Though I have not set any Supervisor and User Passwords for BIOS but still I press "Y", so another message will come like : "Please Turn off power and reinstall the jumper in Normal mode position".
"1st message during BIOS jumper 2-3 position.JPG"
"Exit message during BIOS jumper 2-3 position.JPG"
In this "Step 02" my Intel DH67CL motherboard is giving BIOS display every time & I can see all the menu's of BIOS & I can do changes in it & by pressing "F10" I can save it & can exit from BIOS. Here I can see 4GB + 4GB RAM installed in DIMM1 & DIMM2 so I can not do doubt on any of the RAM module's functionality when PC is not giving display when I am doing "Step 01". Same way I can not doubt on power supply (SMPS) as every time PC is giving display when I connect BIOS configuration jumper in to 2-3 position.
Moreover, since I buyed my PC in August' 2012 year to till date, every 30 days I am blowing air inside the PC's cabinet & inside power supply (SMPS) through air blower machine so dust particles + moisture combination will not create short circuit on electronic components. So since August' 2012 to till date, my DH67CL moherboard always looks like brand new motherboard like intel company is giving to customer in seal pack antistatic bag + box. Though my home, my room are so neat & clean so no problem of dust.
Step 03 I am doing :
I switch OFF the PC, again I remove BIOS configuration jumper from 2-3 position & insert in 1-2 position. I again switch ON the CPU but as usual my Intel DH67CL motherboard is not giving display as I mentioned in above "Step 01".
Step 04 I am doing :
To overwrite my already latest BIOS version 0160 to the same version 0160, I have downloaded "BL0160.BIO" file to FAT32 formatted USB pendrive from ( https://downloadcenter.intel.com/download/22273) and followed the steps for...
n_scott_pearson
Super User Retired Employee
I suggest that you try a CMOS clear. Power off the PC, unplug it from A/C power and then remove the CR2032 battery from the board for a full 15 minutes. After the 15 minutes, restore the battery, plug the PC back in and power it on. You will have to go into BIOS setup and set the date and time. While you are there, I suggest that you do a F9 to reset the BIOS configuration. Then, make any changes to the BIOS configuration that are absolutely required (boot order, etc.) and then exit BIOS setup with a save of the configuration.
Hope this helps,
DPate11
Dear Mr. N. Scott Pearson,
Thank you for understanding my question & thank you very much for your efforts for quick reply to me.
Well sir, as you have written steps in your reply, already earlier I have 100% exactly done this activity many times step by step but unfortunately I forget to write about it as "Step 06 I am doing" in my above question before I posted it at "intel community".
Step 06 I am doing :
Mr. "N. Scott Pearson" reply's each step is exactly I have done many times + after removing the CR2032 battery from the motherboard, I waited for 1 hour or more than 1 hour each time, then I have done "Step 01" & "Step 02" as I mentioned above but result for "Step 01" is as per written in "Step 01" & result for "Step 02" is as per written in "Step 02".
So still I am waiting for possible technical solution of the above mentioned problem in "Step 01".
n_scott_pearson
Perhaps your HDMI connector has failed. Have you tried connecting the monitor using the DVI connector?
DPate11
24th September' 2016.
Once again thank you very much for your quick reply to me.
Its about your doubt on failure of HDMI port of DH67CL motherboard.
My clarification about "Step 02" :
Sir, as per I have written above, if I am doing "Step 02", the BIOS configuration jumper position I am keeping at 2-3 (Configuration mode) & now if I am switch ON & switch OFF the CPU for 50 times then all the 50 times my Intel DH67CL motherboard will give BIOS display !!!!! So for this reason for "Step 02", there is no doubt / no possibility of HDMI port is faulty or fail. Are you agree with it & am I right at here ? (PC will not boot O/S in this "Step 02" as BIOS configuration jumper position is set as 2-3).
My clarification about "Step 01" :
Now to do the regular use of PC on daily, I have to keep BIOS configuration jumper position at 1-2 (Normal mode) as per I have written above in "Step 01", so according to it, now if I am switch ON & switch OFF the CPU for 50 times then out of these 50 tries, in most of the try, no display will come & may be very randomly & very rarely DH67CL motherboard will give display & and then PC will boot also either from any O/S which I choose by pressing F10 button & for the whole day to night I can work on my PC. During work time to keep rest for myself, I am keeping my PC in "Sleep" mode so when I return back to PC, just by pressing any of the key of keyboard, I can start my PC from "Sleep" mode to "Normal" mode. If during the rest time, instead of keeping my PC in to "Sleep" mode, if by mistake I have done "Restart" or "Hibernate" or "Shutdown" then there is no guarantee that next time whether my DH67CL motherboard will give display or not !!!!!. So for this reason for "Step 01" also, there is no doubt / no possibility of HDMI port is faulty or fail as randomly it gives display. Are you agree with it & am I right at here ?
From August' 2012 to August' 2014, I was using DVI to VGA converter connector to attach my 15" CRT monitor "Samsung Samtron 45Bn" & PC was giving display all the time & working fine with it with BIOS configuration jumper position at 1-2, Normal mode.
In August' 2014, I have buyed "Dell S2340L" LED IPS 23" HDMI full HD (1920*1080p) monitor having VGA & HDMI both video input ports but from August' 2014 to till today in September' 2016, I am using my Dell S2340L monitor by connecting it with HDMI port of my Intel DH67CL motherboard & PC was giving display all the time upto few days ago with BIOS configuration jumper position set at 1-2, Normal mode. Even though no changes I made in BIOS, still suddenly & surprisingly its started randomly giving display even though BIOS configuration jumper position is at 1-2 (Normal mode) !!!!!
If I will not get this problem's solution then if I will start to keep my PC in "Sleep" mode instead of "Restart" or "Hibernate" or "Shutdown" but 2 drawbacks of doing of this are :
(1) If 230V AC power supply (electricity) will fail in my home for more than 15 minutes then compulsory I have to do either "Hibernate" or "Shutdown" of my PC as my APC UPS backup time is 15 minutes & then there is no guarantee that next time whether my PC will give display or not !!!!!
(2) If suppose I have boot my PC from HDD1 O/S which has Windows 7 Ultimate 32 bit O/S installed & now I want to work through HDD2 O/S which has Windows 8.1 Enterprise 64 bit O/S installed, in this condition or in vice versa condition, I have to do "Restart" or "Shutdown" of my PC & then there is no guarantee that next time whether my PC will give display or not !!!!!
n_scott_pearson
There are two possibilities to consider: (1) hardware failure on the board and (2) corruption of BIOS configuration.
I am leaning towards the issue being a hardware failure, so let's talk about this case first. The fact that the board will properly enter BIOS Setup when the jumper is in the 2-3 position does not mean that this cannot be the case; the BIOS uses only minimal resources - and it may not be affected by the failing hardware - in this case. Secondly, the fact that the board will sometimes boot and operate properly indicates (to me) that you may have a component that is failing intermittently, possibly as a result of its thermal state (i.e. it needs to be heated up to work properly). If I am right, your only resolution will be to replace this motherboard.
Ok, it you really want to try to recover the board (presuming the latter issue), here's what you need to do. Do it all and do it exactly as I detail it; it does not matter what you have or have not tried before:
  1. On another Windows-based PC (DO NOT USE A LINUX-BASED PC!), insert a USB 2.0 flash disk (DO NOT USE USB 3.0 FLASH DISK!). Reformat this disk using the FAT32 file system (I don't care if it has been formatted or used before, reformat it again!).
  2. Download the latest available BIOS file for your board (that's file BL0160.BIO). Place this file in the root folder of the USB 2.0 flash disk.
  3. Properly eject this flash disk before physically removing it from the PC.
  4. Unplug your DH67CL system from A/C power.
  5. Remove the CR2032 battery.
  6. Remove the BIOS Configuration jumper completely.
  7. Wait at least 15 minutes.
  8. Restore the CR2032 battery to the board.
  9. Plug the USB flash disk into a (black) USB 2.0 port (DO NOT USE (BLUE) USB 3.0 PORT!) on the rear panel of the board (DO NOT USE FRONT PANEL USB PORT!).
  10. Plug the system back in and press power button.
  11. At this point, if the board is working properly, it should proceed to install this BIO file using the Recovery method. If it does not, go no further; replace the board.
  12. If the recovery process actually worked, you should see a message telling you to to power off and restore the BIOS Configuration jumper. Disconnect A/C power and then install the jumper in the 1-2 position.
  13. Restore A/C power and press the power button.
  14. If it powers on properly, use F2 key to enter BIOS Setup.
  15. Set the date and time.
  16. Use F9 key to reset the BIOS configuration.
  17. Make any changes you absolutely need to make to the BIOS configuration (i.e. boot order, etc.).
  18. Exit BIOS Setup saving the configuration.
  19. See if it will boot (more) successfully.
Hope this helps,
DPate11
25th September' 2016.
Thank you very much for your efforts for me.
On 23rd September' 2016, in my question I posted, in the paragraph of "Step 04 I am doing", I have written about I have successfully done BIOS version 0160 (BL0160.BIO) overwrite by following intel's which websites & I have also attached its screenshot JPG file name as "BIOS version 0160 was overwrite successfully.JPG". I request, please once again refer that paragraph & JPG screenshot.
Now about your last reply, my updated are as below :
About your suggested step 01 to step 03 :
I have done with my "IBM Thinkpad R40" old laptop having Windows 7 Ultimate 32 bit O/S I installed in it. I have used HP make USB 2.0 pendrive.
About your suggested step 04, 05, 06, 07, 08, 09, 10 :
I have done.
About your suggested step 11, 12, 13 :
I have done. On 23rd September' 2016, in my question I posted, in the paragraph of "Step 04 I am doing", I have written about I have successfully done BIOS version 0160 overwrite & I have also attached its screenshot JPG file name as "BIOS version 0160 was overwrite successfully.JPG".
About your suggested step 14 :
At here PC was powering ON but as BIOS configuration jumper was in 1-2 position, as usual no display was came even after BIOS version 0160 (BL0160.BIO) overwrite !!!!! ????? So I power OFF the PC, I removed jumper from 1-2 position (Normal mode) & inserted jumper in 2-3 position (Configuration mode), re-power ON the PC & now BIOS display came !!!!! ????? But its meaning less for me as further PC can not be boot with O/S in this 2-3 jumper position. So by this way, with 2-3 jumper position I auto entered in BIOS as no need to press F2 at here.
About your suggested step 15, 16, 17, 18 :
I have done it with BIOS configuration jumper was in 2-3 position (Configuration mode). Though you have suggested to do step 12 to step 19 with BIOS configuration jumper in 1-2 position (Normal mode) but as my DH67CL motherboard is randomly giving display in this 1-2 jumper position, so I have to do step 15, 16, 17, 18, 19 with BIOS configuration jumper in 2-3 position (Configuration mode). Later I power OFF the PC.
About your suggested step 19 :
I have done it with BIOS configuration jumper again set in 1-2 position (Normal mode). I powered ON the PC, there was no display came as usual !!!!! ????? Its really very surprising, shocking & unpredictable behavior of my Intel DH67CL motherboard, but its true !!!!! ?????
Now I think I have to write an e-mail to Intel company to ask them whether they are doing repairing of Intel motherboard on chargeable basis or not as 3 years' warranty of my DH67CL motherboard has been expired.
Well, once again thanks lot dear Mr. N. Scott Pearson for your all the important sequential 19 steps you have written for me & I have tried to explain you above that what exactly I have already tried for each 19 steps but still my problem has been not solved.
So still I am waiting for possible technical solution of the above mentioned problem in "Step 01" from entire "intel communities".
n_scott_pearson
Look, do you want help or not? I don't care what you have tried before. Follow my instructions exactly, to the letter, every single step. If you are not willing to do so, then don't ask for any more help.
DPate11
My intention was not at all to deny your instructions but before posting the question on "intel community" website by me, I have tried earlier so many different possible options, so all that my tries just I was updating to you in my reply. I am extremely sorry if I have hurt you unknowingly.
Well, today on 25th September' 2016, in the morning & in the evening, total 2 times, I have followed your instructions & I have done every single step (all the 19 steps) sequentially & exactly as per you have written in your reply of dated 24th September' 2016. BIOS version 0160 (BL0160.BIO) overwrite successfully both the times, but unfortunately & I feel very sad to write here that there was no display came when BIOS configuration jumper position was set at 1-2 (Normal mode).
Today I have formatted USB 2.0 pendrive in my "IBM Thinkpad R40" old laptop having Windows 7 Ultimate 32 bit O/S & copied BIOS version 0160 file "BL0160.BIO" on its root I downloaded from intel website : "https://downloadcenter.intel.com/download/22273 https://downloadcenter.intel.com/download/22273" (Your step number 1).
Today both the times, after removing CR2032 battery, I was waited for 45 minutes (Your step number 7 suggested to wait atleast 15 minutes).
Today both the times, I have used USB 2.0 pendrive & both the times I have inserted USB 2.0 pendrive in to DH67CL motherboard's USB 2.0 port of rear panel, not in Blue color USB 3.0 port of rear panel. (Your step number 9).
And at last, if still I keep BIOS configuration jumper in 2-3 position (Configuration mode) then display is coming !!!!! ?????
Thank you.
I am editing this reply as I want to add below update for you.
Today on 25th September' 2016, after updating you about my activity I have done as above, I was doing switch ON & switch OFF the CPU near about 50 times then during these 50 unsuccessful tries, no display was came & now randomly for the 1st time in the night, display came with BIOS configuration jumper was set as 1-2 (Normal mode) & by pressing F10, I choose to boot my PC from HDD1 Windows 7 Ultimate 32 bit O/S.
n_scott_pearson
Again, I believe that your board has suffered a component failure. It appears (to me) that the component is (now) operating intermittently, perhaps as a result of its thermal state. My recommendation is to replace the board.
DPate11
26th September' 2016.
Sir, I want to update you below 3 results as after reading them you may find some different idea / some different solution.
Activity 01 : (This activity done "by mistake") :
Today on 26th September' 2016, once again I have followed your instructions & I have done every single step (all the 19 steps) sequentially & exactly as per you have written in your reply of dated 24th September' 2016. But after doing your step number 12, "by mistake" I forgot to remove USB 2.0 pendrive from the DH67CL motherboard's rear USB 2.0 port & I have done your step number 13 (Restore A/C power and press the power button).
Result for Activity 01 :
Unbelievably & surprisingly its started BIOS overwritting / updating process & BIOS version 0160 (BL0160.BIO) overwrite successfully also that I can see on my screen even though BIOS configuration jumper position was set at 1-2 (Normal mode) as per your step number 12 !!!!! ????? Technically whether its correct happening or wrong happening that I don't know / I am not sure about it.
Activity 02 :
Today on 26th September' 2016, once again I have followed your instructions & I have done every single step (all the 19 steps) sequentially & exactly as per you have written in your reply of dated 24th September' 2016 & the same I have also done 2 times on 25th September' 2016 & I have updated you on 25th September' 2016.
Result for Activity 02 :
Today also the same result like BIOS version 0160 (BL0160.BIO) overwrite successfully but no display came when BIOS configuration jumper position was set at 1-2 (Normal mode). Since today morning I have minimum 30 times power OFF & power ON the CPU, but no display is coming with BIOS configuration jumper position is set at 1-2 (Normal mode).
Repeated Activity 01 : (This activity done "by intentionally") :
Today on 26th September' 2016, again I have repeated today's above mentioned "Activity 01". This time in doing your step number 12, instead of removing USB 2.0 pendrive from USB 2.0 port of motherboard, I "intentionally" keep USB 2.0 pendrive in the DH67CL motherboard's rear USB 2.0 port & BIOS configuration jumper position was set at 1-2 (Normal mode) & I have done your step number 13 (Restore A/C power and press the power button).
Result for Repeated Activity 01 :
Same as above written in "Activity 01".
So dear Mr. N. Scott Pearson, please guide me about,
(1)
Whether the result of today's done above "Activity 01" is technically correct or wrong ?
(2)
In your reply of dated 24th September' 2016, in your 2nd paragraph, you have written like : ".....the fact that the board will sometimes boot and operate properly indicates (to me) that you may have a component that is failing intermittently, possibly as a result of its thermal state (i.e. it needs to be heated up to work properly)".
On 25th September' 2016, you have again written about your doubt on probably failure of the same component name "thermal state".
So can you please guide me that on motherboard where exactly this "thermal state" component is located ?
I will be highly thankful to you if you can send me its location JPG file photo by doing RED color round marking through "Paint" name inbuilt program (mspaint.exe) of Windows so I can see it & get awareness about failure component. To send me JPG file photo, my e-mail address is "mailto:patel_dhiren@rediffmail.com patel_dhiren@rediffmail.com"
Waiting for your kind suggestions on these.
Thank you for your support every time.
n_scott_pearson
If you have the jumper located on pins 1-2 and it still does a recovery install of the BIOS, then the jumper is not working properly (not shorting (connecting) pins 1-2). This has happened to me before; the metal portion of the jumper falls out of the plastic housing. Look closely at the jumper; can you see the metal piece? If not, you need to get a new jumper. An electronics supply store should be able to provide you with one. I would note that this could also explain what has happened in general; if there is no jumper (or jumper is missing metal portion) and there is no USB flash drive providing .BIO file, the system would just sit there and not initialize graphics at all.
By "thermal state", I am referring to the temperature of the component. Often, components may fail in such a way that they sometimes operate properly when the component at in a particular temperature range but they always fail at lower temperatures. Now, as to which component(s) might actually be failing (if indeed any are) is unknown. Some components (capacitors, resistors, diodes, etc.) may show visible damage (melting, black marks, leaking liquids, etc.) while others will look just fine and there is no way to tell.
DPate11
27th September' 2016.
Sir, today morning I have disconnected all the cables - connectors (SATA, USB, RJ-45, SMPS connector, 3.5 mm audio, etc.) connected with motherboard & take out DH67CL motherboard from PC's cabinet. I tried to observe motherboard with magnifying glass very carefully & I found that there is a silver color small capacitor surrounded by white color plastic small supporter stand with hole in it so capacitor can be stand firmly & can be pass through plastic supporter near "PCH" (Platform Controller Hub) of Intel DH67CL motherboard which has 2 terminals soldered on motherboard, I found this capacitor is become loose from its soldering on motherboard. Through magnifying glass I found that this capacitor's both terminals are become very weak due to atmospheric corrosion. Due to the limitation of this "intel community" website that one can attach file attachments only 1st time when he / she submit question, in later conversations one can not attach file attachments, so for this reason I am not able to send you photo of this capacitor's location on DH67CL motherboard for better understanding.
Later outside of the PC's cabinet, by keeping antistatic non shorting material sheet below the open motherboard & I have re-connected all the devices' cables - connectors on motherboard & power ON the PC.
Now my observations are :
(1)
If I am very lightly pressing on this component's top side & then pressing the power ON button of my PC then my PC is powering ON but then as per I have written in "Step 01 I am doing", no display is coming (BIOS jumper position is 1-2 "Normal mode). Same way when I am pressing power OFF button of the PC then my PC is not powering OFF but if I am very lightly pressing on this component's top side & then pressing the power OFF button of my PC then my PC is powering OFF.
(2)
Same way, if I have not lightly press on the top side of this component & I am pressing DVD writter eject button then its trey is coming out & quickly auto close but if I am very lightly pressing on this component's top side & then pressing the DVD writter eject button then DVD trey is coming out & wait & when again I am pressing eject button then it will close.
(3)
Same way, when I power ON the PC but then no display is coming as per problem (1) so I press "Reset" button of my PC, at that time RED LED on my PC for HDD is not blinking but if I am very lightly pressing on this component's top side & then pressing "Reset" button then RED LED on my PC for HDD is blinking for a while.
Later that capacitor's both terminals has been automatically broken & that capacitor has been now auto disconnected from my DH67CL motherboard. So now my motherboard is not even powering ON.
So now I have sent an e-mail to Intel company on "mailto:crmotherboard@mailbox.intel.com crmotherboard@mailbox.intel.com" & updated them about all the problems I am facing with my observations & JPG files of screenshots, motherboard photos. I asked Intel that I am from INDIA country so where is the Intel's service center where I can repair my Intel DH67CL motherboard on chargeable basis as its 3 years warranty has been expired, what is the further process to send my Intel DH67CL motherboard at Intel company & on which address should I send it, how should I pay to Intel, etc.
Now I am eagerly waiting for the positive reply from Intel company.
According to your reply of 26th September' 2016, I have verified that my Yellow color BIOS configuration jumper has metal portion inside intact to do shorting / to connect pins 1-2 for "Normal mode" & to connect pins 2-3 for "Configuration mode". By connecting & removing BIOS jumper on 1-2 position & 2-3 position, I have checked pins shorting & open situation through electronic multimeter by touching 1-2 & 2-3 pins solder terminals below the motherboard & multimeter is giving beep noise when jumper is connected & multimeter is not giving beep noise when jumper is removed so its confirmed that Yellow color BIOS configuration jumper is working properly.
I wholeheartedly thank you for your support every time very quickly & your answer is always related to my question, all these are really appreciable. If you don't mind, may I know you are giving me support from which country ? I am from INDIA country.
n_scott_pearson
Unfortunately, Intel exited the Desktop Boards business a number of years ago. There is no longer any service center where you could get your board repaired (at cost or otherwise). As I have said before, if a board this old has failed, you have no recourse other than to try to repair it yourself or to replace it (at your own expense). There are still manufacturers producing boards for 2nd generation Intel Core processors, but, since your processor is also 6 years old (and is not supported by Windows 10), my recommendation would be to replace (upgrade) both the board and processor...
DPate11
28th September' 2016.
Sir, as per I have written on 27th September' 2016, please see the above image in which I have marked RED color square & RED color arrow, I am talking about this component is loose & later auto disconnected from my Intel DH67CL motherboard.
If I will give my DH67CL motherboard to a skilled engineer / technician who is doing motherboard repairing work on chargeable basis in my city / other city, then I think the problems I am facing with my motherboard will may become solve, I may be wrong or right at here. Just because of 1 component's failure, the whole new motherboard + its compatible new processor to be buy is not advisable & is very expensive for me.
Can you please guide me that what is the exact technical name of this component & what is its exact work function on motherboard ?
Thank you & waiting for your reply.
n_scott_pearson
That's not a capacitor; it's a crystal oscillator. It generates the base signal for the real-time clock functionality in the PCH. I am seeing other corrosion on the board (note, for example, the condition of the other crystal oscillator on the left-had side of the picture (between the two larger capacitors)). It looks like I am seeing rust as well. Are you in a really wet climate?
I rather doubt that replacing this oscillator is going to fix this situation. Still, you are welcome to try...
DPate11
29th September' 2016.
Sir, thank you very much for giving me guidance of its actual technical name (crystal oscillator) + its work function on motherboard. Now I have read few about it by searching on "google" to get little knowledge about it. The same value of 32.768Khz crystal oscillator are available on online shopping website so either I will buy it & then I will give my motherboard for repairing it to the skilled technician & further he will do his best.
The above photo of my complete motherboard, its always looks like new one / dust free since I buyed in year 2012 as on every month end I was doing air blowing through air blower machine by opening the cover of my PC's cabinet even though no dust inside the PC cabinet.
I am living in INDIA which has 3 natural season like approximate 4 months winter, 4 months summer & 4 months monsoon = 12 months = 1 year cycle will complete. Since I buyed my Intel DH67CL motherboard + Intel i3-2120 processor & I assembled my PC myself in August' 2012, from that day, I have kept small size approximate 10 silica gel crystal packets inside my PC's cabinet to absorb humidty as a 1 step extra protection for my PC + every month end (after every 30 days) I was doing air blowing through air blower machine by opening the cover of my PC's cabinet so dust + humidity / moisture will not create any kind of conductivity on my motherboard between electronic components, as a 1 step extra protection for my PC + PC was connected with UPS of technically skilled proven brand like APC (http://www.apc.com/in/en/ http://www.apc.com/in/en/). So by taking these steps, I have minimize all the possibilities of failure of my PC just because of any technical points' ignorance / negligence by me.
On 28th September' 2016, 2 times phone calls came to me from Intel company (INDIA country) as I have sent 3 e-mails + my observations & relevant JPG file attachments to Intel company (INDIA country) on 23rd, 26th & 27th September' 2016 as I updated them also about problems I am facing with my out of warranty Intel DH67CL motherboard.
So, Intel customer care support executive has told me that Intel has stopped manufacturing of motherboards due to their internal reasons which he can not share with me officially, so he suggested me to buy 3rd party motherboard like ASUS, Gigabye, etc. (which must be compatible with Intel i3-2120 processor that I have to find out) so I can get warranty of that motherboard from that 3rd party company but now if I will again buy new Intel motherboard which old stock may available with computer dealers in the computer market & if in future, if any problem will come in that new Intel motherboard then Intel will not give any warranty support.
I have visited website (http://processormatch.intel.com/ http://processormatch.intel.com/) & found total 58 Intel + ASUS make motherboards which are compatible with Intel i3-2120 processor. So if my Intel DH67CL motherboard will not become repair by any skilled engineer in my city / other city then I have to find out another motherboard out of these 58 compatible motherboards or from 3rd party motherboards companies so atleast I can use my Intel i3-2120 processor with that compatible motherboard & by this way I have to spend money only for 3rd party new motherboard & not to spend money for another new processor as my existing Intel i3-2120 processor was working fine with my existing problem creating Intel DH67CL motherboard.
So now I have started exercise to find out 3rd party motherboard of ASUS, Gigabye, etc. which has almost the nearest / same numbers of ports' quantity like currently my Intel DH67CL motherboard has for SATA 6.0, SATA 3.0, eSATA, USB 3.0, USB 2.0, DDR3 1333Mhz RAM compatibility, DIMM slots, 7+1 audio ports, RJ45 LAN, HDMI, (DVI to VGA optional, dual display optional), PCI, PCIe, etc. so all my existing peripherals like USB webcam, USB HDD, USB steering wheel gaming joy stick, USB pendrive, USB cable of APC UPS funcionality monitoring (UPS funcionality monitoring can be done through "PowerChute Personal Edition" S/W of APC), Bluetooth USB adapter (to listen wireless music from my PC through Logitech bluetooth audio adapter to Altec Lansing VS2421 2.1 woofer), USB K/B, USB mouse, USB 4 port hub - - all these peripherals I was always keep connected at a time with my DH67CL motherboard so I never had to remove any of the peripheral from my DH67CL motherboard. I am searching new motherboard of 3rd party for the same ports' usefulness. That's why in the year of 2012, I have done too much reading on Intel website & I made a proper comparision sheet of how many quantity of differnt ports are available in all the Intel motherboards & in the year of 2012 I have read about approximate 103 Intel motherboards' technical details & then according to the price I can spend for the features I needed in my motherboard, finally I decided to buy Intel DH67CL motherboard, so by this way this motherboard is very important for me, I never buy any equipment / any gadget randomly, before buying it, I always study its excellent technical work performance & its actual usefulness for me.
Logitech bluetooth audio adapter :
http://www.logitech.com/en-in/product/bluetooth-audio-adapter http://www.logitech.com/en-in/product/bluetooth-audio-adapter
Altec Lansing VS2421 2.1 woofer :
https://www.cnet.com/products/altec-lansing-vs2421/specs/ https://www.cnet.com/products/altec-lansing-vs2421/specs/
Thanks a lot for answering me + guiding me.
n_scott_pearson
No problem. Frankly, I don't believe that a repair attempt is worth the effort (or cost), but that's your decision to make...
DPate11
02th October' 2016.
On 01st October' 2016, I have given my Intel DH67CL motherboard for repairing to a skilled technician & my disconnected "32.768 KHz Crystal Oscillator" component has been replaced with same new "32.768 KHz Crystal Oscillator" component & the problems due to this component has been solved about which I have written on 27th September' 2016, but still the original problem which I have posted on 23rd September' 2016 is pending to solve by that skilled technician, I am waiting for any good news from him as he is still doing further troubleshooting. Later also I will update you its final status of whether its successfully repaired or not as soon as I will get update from that skilled technician.
Now if suppose for any technical reason, if my Intel DH67CL motherboard will may not possible to repair by that skilled technician, then parallel, I have started to search out new motherboard which is compatible with my Intel i3-2120 processor.
As per dear Ivan's reply to me of dated 29th September '2016, "Asus" brand motherboards are compatible with my "Intel i3-2120" processor, so to find out compatible Asus brand motherboard I have visited website :
http://processormatch.intel.com/MotherBoards/CompatibleBoards%3FcomponentName%3Di3-2120 http://processormatch.intel.com/MotherBoards/CompatibleBoards?componentName=i3-2120
And I have found total 58 compatible motherboards of Intel & Asus brands which are compatible with my "Intel i3-2120" processor.
Out of it,
form factor ATX compatible Asus motherboards = 4 Qty.
form factor microATX compatible Asus motherboards = 13 Qty.
form factor mini-ITX compatible Asus motherboards = 2 Qty.
I am interested to buy Asus motherboard at 1st priority for ATX form factor motherboard as it has more numbers of ports & expansion slots & 2nd priority for microATX motherboard as it has less numbers of ports & expansion slots. I am not interested for mini-ITX form factor motherboard as its has still more less numbers of ports & expansion slots even than microATX motherboard.
In INDIA, apart from Intel motherboard, there are other brands like Asus, Gigabyte, MSI, Asrock & so many other unknown brands of CHINA country manufactured motherboards are available. But as Intel company's above official websites' recommands / suggests for Asus brand motherboard, so I will buy new Asus motherboard, if my existing Intel DH67CL motherboard will not be repair by skilled technician.
So my request to you is :
I have visited website : (http://processormatch.intel.com/MotherBoards/CompatibleBoards%3FcomponentName%3Di3-2120 http://processormatch.intel.com/MotherBoards/CompatibleBoards?componentName=i3-2120) & by choosing Asus motherboard from it, its redirected me to the relevant Asus motherboard's website but the technical informations written on website (http://www.asus.com/US/Motherboards/ http://www.asus.com/US/Motherboards/) are not accurate, doubtful, not clear to understand, few motherboards' model numbers are different but opening the same webpage ,the motherboard images are not clear to see in normal & zoom view mode, etc. while on Intel website (http:www.ark.intel.com) each & everything is 100% perfect.
So for this reason, I am facing trouble & getting confused to choose compatible Asus motherboard due to incomplete technical informations on Asus website, so I am sending you this post to guide me / suggest me the list of "Asus" brand motherboard which are compatible with "Intel i3-2120" (3.30Ghz) processor + it has almost
all the different ports, expansion slots, etc. which are almost in "Intel DH67CL" motherboard + possibly almost the same number of quantities as per in "Intel DH67CL" motherboard. As you may have more numbers of years' wide technical experience in such type of matters, I am approaching to you.
I have following numbers of ports in my "Intel DH67CL" motherboard :
SATA 6Gb/s = 2 Qty. onboard.
SATA 3Gb/s = 2 Qty. onboard.
eSATA = 1 Qty. onboard + 1 Qty at back panel of motherboard.
USB 3.0 = 2 Qty. at back panel of motherboard.
USB 2.0 = 6 Qty. at back panel of motherboard.
USB 2.0 = 8 Qty. through optional wire connectors to be connect on motherboard, there are 4 connectors on motherboard & each connector supports 2 Qty. of USB 2.0 ports.
DDR3 1066MHz, 1333Mhz RAM compatible DIMM slots ...
n_scott_pearson
As Doc pointed out, we cannot tell you what to buy. Here are some recommendations for your consideration:
  • My biggest recommendation would be to replace the 2nd generation Core i3 processor and upgrade to a 6th generation Core i3/i5/i7 processor and a 10 Series board (i.e. one with Z170, H170, H110 or B150 chipset). This will also mean setting aside your DDR3 memory and replacing it with either DDR3L or (better) DDR4 memory. Yes, this is a costly recommendation, but your existing processor is 4 generations and 5 years out of date - old enough that Intel isn't even supporting it on Windows 10.
  • It your are going to stay with the 2nd generation Core i3 processor, I recommend that you go with a 7 Series board (i.e. one with Z77, H77 or B75 chipset) instead of a 6 Series board. Most 7 Series boards have support for the 2nd generation Core i3/i5/i7 processors (but verify this support before purchasing!). Upgrading to a 7 Series board should not cost you much extra (if any) and doing so offers a number of advantages including improved SATA III support and (chipset-based) USB 3.0 support (including native front panel support). Whether you choose a Z77, H77 or B75 chipset-based motherboard depends upon what you want to do with the board and what your longer-term plans are. For example, if you might, at some point, upgrade to a 3rd generation Core i5 or (better) Core i7 processor, then I would recommend that you pay the little bit extra now and get a H77 or (better) Z77 chipset-based motherboard.
There are a lot of motherboard manufacturers out there with reasonable quality processors. I won't steer you towards any particular one - but I do suggest that you pay attention to the reviews of their quality (including BIOS), reliability and customer service (especially within your own country!)...
Hope this helps,
Community Manager
Hello DhirenPatel,
I agreed with N. Scott Pearson, the motherboard seems to be defective and it needs to be replaced.
At this point, I strongly recommend taking N. Scott Pearson suggestions as he always provides very good suggestions.
Best wishes,
Ivan
