Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
My current audio display driver is: 6.16.0.3200 6/22/2017 Looking for the most recent update. Thanks
RNewm3
AlHill
What is the model number of your Intel Desktop Board?
Doc
RNewm3
Thanks. Here are the specs: Alienware X51 Service Tag : BVBTSW1 Express Service Code : 25838923393 Computer Model : Alienware X51 BIOS Vendor : Alienware BIOS Version : A14 BIOS Date : 11/4/13 Processor Processor : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz Clock Speed : 3.4Ghz L2 Cache Size : 1024 Memory Available Memory : 54.45% Page File Size : 9,367.2MB Available Page File : 98.10% Virtual Memory : 9,367.2MB Available Virtual Memory : 44.35% DIMM1 : 4,096.0MB DIMM2 : 4,096.0MB Network controller Adapter Realtek PCIe GbE Family Controller Storage Drive : C: Storage : 3 Drive Size : 227.1GB Total Available Space : 155.2GB Used Space : 71.9GB Drive : D: Storage : 5 Drive Size : Total Available Space : Used Space : Hardware Disk Drives SAMSUNG SSD PM830 2.5" 7mm 256GB Display Adapters Intel(R) HD Graphics 4000 NVIDIA GeForce GTX 660 Keyboards, Mice & Pointing Devices USB Input Device Monitors ACER S271HL Dell U2212HM (Digital) Sound Devices USB Audio Device Intel(R) Display Audio Realtek Audio NVIDIA Virtual Audio Device (Wave Extensible) (WDM) NVIDIA High Definition Audio USB Controllers Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26 Renesas USB 3.0 eXtensible Host Controller - 1.0 (Microsoft) Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
AlHill
Well, that is not an intel desktop board.
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
RNewm3
n_scott_pearson
Super User Retired Employee
That version number sounds like a RealTek version number. The latest version of the RealTek driver should be available via Windows Update and automatically installed. If no update is available there, then you have the latest version already.
If you are asking about the audio being delivered to your monitor/TV via DisplayPort or HDMI, then the necessary driver will be installed along with the graphics driver -- and this applies to driver packages for Intel HD Graphics, NVIDIA HD Graphics and AMD HD Graphics.
Hope this helps,
RNewm3
Thanks. Everything works fine. It’s the Intel Display Audio driver I’m asking about. The current driver is version 6.16.0.3200 6/22/17. I understand there’s a newer version, 6.16.0.3208 however I’m unable to find it anywhere.
n_scott_pearson
As I said, it is included in and installed by the Intel HD Graphics driver package.
RNewm3
Thanks. If I could get link to download this Intel audio display driver that would be great: 6.16.0.3208 4/26/2018.
n_scott_pearson
If you have a add-in (NVIDIA, AMD) graphics card installed, the Intel HD Graphics 4000 engine in your processor will typically be disabled. In this case, if you are connecting the TV/monitor to a DisplayPort or HDMI output from this add-in graphics card, you install the audio driver by installing the graphics driver for that card.
If you do not have an add-in graphics card, then the Intel HD Graphics 4000 engine in your processor will be your primary and you would be connecting the TV/monitor to a DisplayPort or HDMI output from this motherboard. In this case, if you install the Intel graphics driver package (download it from here: https://downloadcenter.intel.com/download/29473/Intel-Graphics-Driver-for-Windows-15-33-?product=814...), you will also be installing the audio driver..
RNewm3
Really appreciate this. Many thanks.
