Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
NEED HELP
hello friends,
my self ashish. I have a DG41RQ motherboard, core2duo E7500 processor. The problem is that when i play games like nfs-most wanted my monitor color got blurred. When i first encounter this problem i thought that there may be some problem with the game only because rest of the games were running normal like GTA-san andreas but yesterday when i installed fifa08 the color of this game also got blurred.
i am very much confused what should i do whether the problem is with my motherboard graphic driver or some where else..........
please do help
Highlighted
Community Manager
1 View
are you using the onboard GPU?
Highlighted
Community Manager
1 View
yes i don't have a graphic card. i am using onboard GPU only......
Highlighted
Community Manager
1 View
All you can do is turn graphics settings in the games down,
update the driver
check temps for overheating
Highlighted
Honored Contributor I
1 View
Your Best bet would get a good add-on Graphics card todays Games require such high frame rates that onboard graphics will not work good. A single good card will be at least $100.00.
